Gen 4 Rebuild by with pics
Doomanic
🛠️Wrecker🛠️
8,718
10,383
In Nov 21 I relegated my Rail to second bike status after I bought a Kenevo SL.
In March 22 I decided to try and sell it as I needed the space in the garage. Unfortunately, when I took it out to clean it up for pics I realised that the motor wasn't working; it powered up and walk mode worked but pedalling did nothing. As it was out of warranty I got in touch with @Bearing Man and arranged a strip down and repair estimate.
This was the response;
Water/dirt has got in through the left hand crankshaft bearing which is what typically happens with the Gen4 motor we have found. The crankshaft assembly was semi -seized together as was the left hand crankshaft bearing. Please find attached estimate to repair, if you are happy to proceed just let us know and we will get your motor repaired as soon as possible.
And the quote for repair;
And here's the pics he sent me...
The repair was completed in quick order and the motor has performed flawlessly ever since. I think the cost of repair was fair for the amount of work involved and the turnaround was very fast.
My apologies to @Bearing Man for not posting this sooner, but procrastination is my middle name....
Tony4wd
258
221
It was dirt! This is not uncommon with the Gen 4 once the crankshaft bushes wear badly.
Can owners tell whether the crankshaft bushes are significantly worn by feeling for movement in the crankshaft? Will the shaft move up/down by a millimeter or two?
Bones
890
1,163
Harrogate
Interesting about the bushes as mine has a mm or so of play in the crank arms. The shop recons that's acceptable?.
It has done just over 4k hard miles 🤔
Ark
460
386
Newcastle Upon Tyne
I was just googling if anywhere near me does it for mine when the time comes.
cycletech list it on their website as a service
and they have people all over the country that will collect your bike or do the work at your house.
makes me wonder if they can do a bearing change without sending the motor off anywhere then, maybe even Infront of you whilst you watch and take photos for us :D
In the middle halfway down this page
Find one near you Locations | Find a cycle technician within striking distance and ask them :)
Bearing Man
Ebike Motor Centre
971
2,322
Because these are bushes and not bearings, you will feel a slight bit if play, even on a new Gen 4 motor. This is usually around 2mm by the time it gets to the very end of the pedal arm.
The picture below shows how the dirt gets into the motor and you can see the plastic bushes shown on our cutaway.
arTNC
240
281
Texas
Move to Utah?
LOL!...yes...or west Texas. I know you folks in the UK and other often wet environments would lose a ton of good riding time if you refrained from riding in the wet, so I totally understand. I just won't hardly ride my dirt motor or my MTB/emtb in water or mud anymore. Decades of racing my state's dirt motor enduro circuit involved rain or shine commitment. I just don't have to do that anymore, and the number of dry vs. wet days is favored strongly by the dry days in my home area and yes...southern Utah which I visit somewhat frequently. I'm sure there is still dust/dirt ingress to some degree but at least not accelerated by water. Very interesting thread about this issue and the service that fixed it. Thanks.
Ark
460
386
Newcastle Upon Tyne
If the shop said water ingress from the left hand crank is 'typical' - What can we do to prevent it?
Refresh the grease every 6 months or so
Some people have also made comments saying from the factory its possible to have barely any grease behind the seal.
Andrew426
23
10
New Zealand
View attachment 136142 View attachment 136143 View attachment 136144
Are there any aftermarket suppliers for that bush? I have my motor apart at the moment, the crank shaft is quite pitted with rust and one of the two bushes is quite worn, causing play in the drive side crank and the assistance to cut out for a split second at a certain point in the crank rotation.
I have an engine rebuilder polishing the shaft and making new bushes for me but I am wondering if there are parts available to buy or if it's a case of buying a new motor if this happens.
Spiff
448
262
Earth
Ebike Motor Centre has an upgrade kit, but I believe you will have to send your motor from the antipodes to them for the parts upgrade.
Bearing Man
Ebike Motor Centre
971
2,322
Yes, these bushes will be soon added to the Bosch parts list. However, if you need some now, just drop me an email through our website.
Stihldog
Handheld Power Tool
3,527
4,949
Coquitlam, BC
I intend to prolong the life of my 2020 Trek Rail with a motor rebuild/upgrade/service after less than 20K kms. Pete has recently posted that an eMTB service centre will be available in NA somewhere (probably in the US).
I have three Bosch Gen4 motors ready to go. Mine is about ready for service. After almost daily use and abuse I know I’m on borrowed time. It’s not making any weird noises or behaving badly …yet.
A motor on my shelf has had the drive-side casing replaced by me. Pete’s distributor in Hull, Quebec (Cyclochrome) provided me with a replacement casing, bearing, bracket and bolts for a very reasonable price. When I opened the motor I had a few concerns. No water ingress. No noticeable wear and tear. Just the colour of the surrounding grease, or lack of grease. This motor is likely due for a service.
The 3rd motor is a mystery to me. It just stopped working. It should be in my hot little hands this week. I’ll probably take a Quick Look inside to see if there’s anything obvious before I send it off for service.
Like some Bosch motor owners I do the best I can to prevent motor failures. Check the motor mounts, bearing seal kit, regular greasing, proper cadence etc. But I still ride in the rain, wash my bike occasionally, ride in the snow, cross rivers and several other abuses.
Maintenance is key. 🤷‍♂️
Andrew426
23
10
New Zealand
Here is a picture of my polished shaft and bushes. My shaft wasn't as badly pitted as the ones in the link another person posted. I have considered putting an oring behind the seal to further prevent water getting in but il have to see if there is space
Bearing Man
Ebike Motor Centre
971
2,322
Do not use an O-ring on this application! An O-ring is classified as a "static seal" and should not be used for a rotating application, especially this application because the torque tube (freewheel tube) and crankshaft must be free rotating. Any drag between these two components can cause run-on and may cause the chain to jump of when back pedalling.
Please remember, we would not spend thousands of pounds perfecting a virtually frictionless solution, if we could have got away with an O-ring. We even discovered that a thin film of grease on the plastic bushes, caused big issues with he motor!
Tone461
119
247
West Midlands
When I sent my GFs 3000 ml Bosch motor in to Pete, I was pretty confident it would only require a minor refresh. I knew the previous owner had looked after it and it had never shown any problem at all. There was no play in the crank arms at all, I'd repacked the seals recently, it was never jet washed and my GF is defiantly not a freestyle type of rider, or pedal strikes it a lot (less than me Opps).
When he stripped it and showed me the photos of the motor I had a shock to say the least! Water had leaked past the right hand seal rusting the shaft as in Doomanics post and also showed signs of ingress on the other side. The PCB showed early signs of water ingress as well. Gutted!
I think the damage had been done before I did the seals so I still think its a worthwhile job.
Anyhow, Pete and his team did their magic and now its still as strong as ever, For me, both the motors ( mine as well) are now going to peters as part of a yearly check up. You may think you've treated it well, done all the right things but you might be in for a shock!
Andrew426
23
10
New Zealand
OK il forget the oring. So you don't recommend grease between the shafts either? Mine had evidence of grease in it. Unfortunately I wasn't the one to take my motor apart, I just got it back in a box after I paid for a rebuild so I'm not totally sure what did/didn't have grease on it to begin with.
Bearing Man
Ebike Motor Centre
971
2,322
We see very few (4 so far) with a light grease on the crankshaft, but this maybe winding it's way through from the drive gear or excess grease around the right hand crankshaft bearing. The plastic bushes are manufactured from a self lubricating plastic, so grease is not necessary, and if heavy grease is used it will cause drag when freewheeling or back pedalling.
Andrew426
23
10
New Zealand
I have taken it for a quick test ride, only about 20m up the street and back as my shock is away for a service and I've put another one in there that fouls on the frame. But it works. It assists, feels normal, I can back pedal the crank and it doesn't drag the chainring backwards. So all seems well. Il loctite and torque the crank bolts and take it out for a proper ride when my shocks back. Thanks for your help.
Andrew426
23
10
New Zealand
Fwiw I have done 200km of trail riding on this bike since reassembling the motor (not my main bike) and it performs well, there is no noticeable difference in range or performance and no crank play. I think adding a second green seal would improve the longevity of the motor and could be achieved by cutting 3-4mm (the depth of the seal) off the spacing sleeve and running the drive side bush in further. As it is, I put a bit of moly grease between the flat washer and seal on the drive side of the shaft.
raficzeqq
Sweden
Hello. I have same issue. Which type of seal for the torque tube did you use?. I cant find anything that fits well with 21,5mm shaft and 25.5mm tube. My motor is taken apart right now and i basically got everything except the right seal. Tried to fit multiple seals without any good effect unfortunatelly.
Spiff
448
262
Earth
EbikeMotorCentre has a custom made seal, but I belive you have to ship your motor to them for the installation.
irie
2,559
2,603
Chichester, W.Sussex, UK
554K
