Unanswered Focus jam2 Mullet set up help
Brian311088
Essex
Hi I want to change my rear 29er to a 27.5 mullet set up just not sure what I need to buy im running the shimano 12 speed slx m7100 on my focus jam 2 6.7 2021 any suggestions. Thank you
Doomanic
🛠️Wrecker🛠️
8,688
10,318
A microspline rear wheel in the correct width and a cassette, brake rotor and magnet if you're planning on swapping between wheels. You'll need to get a Bosch dealer to alter the wheel size or you'll lose a bit off the top end. If the bike has a flip chip you'll want to run it in the high setting and even then, pedal strikes are likely to be a common occurrence while you get used to the lower back end.
552K
