ETA for Gen 5 S 180
LautSprecher
76
68
Update: Trackingnumber for frame is available. It should arrive on the third January. Unfortunately I am not at home and will be back the week after. 🫨
Anyone else got their tracking number?
Daveed F
73
168
Truckee, Ca
I see that Probike supply store, (Ca, US) has a few frames and complete bikes (RH3 only) low stock on line also available at the shop, so it means they got the December delivery!
I’m waiting for the February shipment. !!!!!!
2supple
18
11
Denver, Colorado
I am December delivery but told that things are a little behind, hoping they get the container end of next week, and then I imagine a few more days before it’s ready to go out, but not sure.
mrtrinh
19
28
Orange County, CA
Did you figure out your crankset/chainring set up? Since I can't find 155 sram cranks I'm debating between 150 or 160. Bb height is pretty high compared to everyone else.
2supple
18
11
Denver, Colorado
Yeah I ordered the e13 helix core e-spec. I emailed them and they said they fit, they come in 155 length and with their Xmas code I got them for $63 shipped. They actually look pretty decent in person too. If I was going to spend a little more I’d get the Pinnd ones in silver, but for so inexpensive I couldn’t pass the e13. Also the Pinnd in silver are currently out of stock which is another reason I got the e13.
Regarding chainring I’m going with the sram branded t type 36t steel that they make for transmission.
Ou812
947
743
Inverness
Are you guys going with 600 or 800 battery? I missed the first batch of frames and there’s only a few left for the second batch. I’m thinking the 600 and getting the range extender for the longer days.
Robstyle
134
159
New Zealand
You can't go wrong with either size I reckon. I ordered with a 600 specifically for the weight. I think the 600 will be dialled for 95% of the stuff I do. If I start running outta battery I'll just buy a 2nd battery in 800 flavor. I would rarely max out a 750 for reference.
LautSprecher
76
68
Teaser.
Bigtuna00
563
341
CA
Mine arrived Jan 18, a day late because UPS had a "mechanical issue". RS Signature Frameset custom build, 46.5 lbs as pictured. Size RH-3, 29/29, 600wh battery. New motor is so quiet, my brain is trained to think I'm in some low power mode :)
Bman
22
20
Dallas, TX
Just got my LS 160 put together. Fantastic bike! Still got some suspension and cockpit tweaks to get it dialed. So far super pleased!
bullit398
20
22
New Jersey
One thing that did surprise me on the new frame is brake cable routing is different. Coming off the same size prior version my hose was way too short. Just something to note if you aren’t installing new brakes with full length hoses they may not be long enough.
576K
