Duggan
Here’s a few pics of my carbon fibre Rock Guardz motor guard. Seems to make sense to give the motor some protection, most other brands are either surrounding the motor in the frame or supplying a guard.
Cheers for posting this, I had checked with Rock Guardz before but they never had one listed for this bike.
I attempted to make one out of ABS plastic but gave up on that. This looks a lot nicer.
Just ordered one. Hopelfully it should be with me for the weekend.[/QUOTE
Hey no trouble ?? I was looking for a guard for a while whilst my bike was on order also, just a bit of peace of mind knowing it’s got some protection from rock damage when tearing down the trails.
Yes I did for like 3 minutes. It was much flexible.I have one now to. Have not fitted yet. Did you put it in hot water before mounting?
Glad you are happy with it. The Rockguardz are ok but they only offer cosmetic protection. My "proper" bash guard WILL NOT break no mater what you bash it on and it protects the chainring too.bought one of these on eBay and couldn't be happier. Excellent build quality, very strong offering great protection, easy to install and fast delivery to Australia:
Merida E bike bash guard | eBay
Great to see it did it’s job.......but, unlike my guards, it won’t take many, if any more, hits to destroy it and then your going to have to buy another. Watch out when you wash it too, with edges and shards like that you’ll look like you’ve been self harming ?. If you break one of mine you’d get a free replacement. I can say that cos you won’t break one. ???.
I will buy one if you refine the design. My feedback - they don't look very nice, they are too thick and reduce clearance, mount crudely at the front which is going to cause rub through of the paint on the frame.Great to see it did it’s job.......but, unlike my guards, it won’t take many, if any more, hits to destroy it and then your going to have to buy another. Watch out when you wash it too, with edges and shards like that you’ll look like you’ve been self harming ?. If you break one of mine you’d get a free replacement. I can say that cos you won’t break one. ???.
I have refined the look of them by rounding and chamfering the edges. They don’t reduce clearance as they are level with the chainring which is your lowest contact point. I use the clear “helicopter” tape all over my frame to stop paint rub and this combined with the Velcro tape supplied with the guard stops any possible damage. The “crude” mounting at the front is exactly the same method you’d use to mount any mud guard. As for looking “nice”, unless you are lying on the ground, you can’t really see them. Constructive criticism is fine but your comments are a bit unfounded plus you’ll do far more damage to your bike without one. Each to their own but personally I can’t see why you wouldn’t want to protect the single most expensive component on this bike. They should, in my opinion, have come with a guard from the factory, although the “guards” on some bikes I’ve seen from the factory aren’t fit for purpose. I also see there are new bikes coming out now with similar guards fitted, like the new Husqavana.I will buy one if you refine the design. My feedback - they don't look very nice, they are too thick and reduce clearance, mount crudely at the front which is going to cause rub through of the paint on the frame.
Cheers for the positive comment, glad you approve.Hi. I have been riding with mine on for a while on my e160 900e and have found that it rarely impacts on clearance and when it does its not an issue as you have piece of mind that your frame, motor and chain ring are protected. I had some concerns about paint rub at the front and wrapped the frame with a 3M film first before using the supplied velco strips and cable ties which securely mount the guard to the frame. As for the appearance I think the guard enhances the aggressive style of the bike.
There is another type on eBay Here. I think the design of this one & yours is superior to the rockgaurds as there is space between the bash & the motor, obviously it will become a shit shelf but it will offer more protection.The only other option regarding guards is the carbon one as in earlier photo
Like the RockGuardZ..They fit nicely, look great, and give enough protection to the engine..
Well, the main damage was top left on the pict (not those scratches on the bottom). Still a little paint came off from the frame, but it saved my frame big time (othervise it would be a hole on the frame. The carbon did the job). As I can see your guard's shape, the critical point would not even covered as the rockguardz does so I'd be in big trouble. The other thing the clearance. Yours waaaay thicker, so I'm already havin' trouble the clearance, I definately don't want another 1 cm. Don't get me wrong, your guard is a kick ass guard too I think, but my advice is don't promote your equipment to say neagtive things to others, I think you're a little agressive on self promoting, but that's just my opinion. Like I said, I still like your guard.Great to see it did it’s job.......but, unlike my guards, it won’t take many, if any more, hits to destroy it and then your going to have to buy another. Watch out when you wash it too, with edges and shards like that you’ll look like you’ve been self harming ?. If you break one of mine you’d get a free replacement. I can say that cos you won’t break one. ???.
If I took a bit off the width and made it out 3mm aluminium and anodised it black would you consider that to be visually appealing? You'd have to accept that it wouldn't be as protective though.I really like the look of that Husqvarna guard. I reckon one of those could be adapted to fit the Merida. Unfortunately I am one of those people who need a product to be both functional and visually appealing. For the time being I have stuck a section of 8mm thick insertion rubber onto the bottom of the motor, so if I do drag the motor, the rubber will take the impact.
No worries.I reckon the Husky guard is visually appealing and offers complete motor protection in exactly the same way that a skid plate on a dirtbike does. I think having the motor guard and downtube guard as two separate items increases visual appeal, and can offer suitable protection. Fortunately for us we have the luxury of choice, and if I cant find a motor guard that I like, I will make one also. Please don't consider this an attack on your product Rallysalon, as I am sure it does exactly what you, and many others want it to do. I am just saying that it is not for me .
That might just be the perfect solution for me. Thanks for the offer. I commend you for producing these guards commercially. If i make my own i dont reckon i would have the time or energy to make them for others. What kind of ballpark price would the mount be posted to Australia? Thanks mateNo worries.
I could supply you with the specially made bracket which my guard bolts to which gives it the strength and rigidity it needs to take the impacts. This was the tricky part to get right when making my guard. With that it's quite easy to make any guard you like fit. I might look at doing another version of my guards one day but I don't really have the time and I'm not making enough money on them either.
Where in Aus?That might just be the perfect solution for me. Thanks for the offer. I commend you for producing these guards commercially. If i make my own i dont reckon i would have the time or energy to make them for others. What kind of ballpark price would the mount be posted to Australia? Thanks mate
Killingworth in the state of New South Wales. Postcode 2278Where in Aus?
