how did you kill it in 29kmDeluxe is nice shock IMO. Yesterday installed Öhlins TTX Air and understood how bad all Rockshox and Fox (including X2 2020) shocks are.
Too bad enjoyment lasted only 29 km before it died ?
how did you kill it in 29km![]()
He fitted it to a Levohow did you kill it in 29km![]()
He fitted it to a Levo![]()
@1Nixxxo I was just poking fun
But...
There's is a fairly well documented flaw in the Levo's suspension design whereby the shock yoke transmits side loads through shock shafts during compression.
Generally the smaller diameter the shock shaft the worse the issue will be
does that cascade components link address this or is it unavoidable?@1Nixxxo I was just poking fun
But...
thought I better research my own question, seems not, it changes the leverage ratio and adds a small amount of travelNo idea Dobbie
@1Nixxxo
I have seen the numerous snapped (aftermarket) shock shafts and this irritates me greatly. I really struggle to see how someone as switched on and experienced as Spesh can design a linkage which adds such excessive side loads. At best its gonna cause unnecessary stiction. At worst...well we know what happens.
It upsets me cos I love Spesh to bits but my engineering head says 'what were they thinking?' I still feel like I need to give the benefit of doubt - maybe an excessive side load is an unfortunate by-product to get an amazing suspension system?
Yes you can, and I did this on a Fox shock to add/remove spacers (Once I'd done it in the garage). One of the bike mags had done trailside spacer swaps and I followed their lead. The problem is in preventing tiny specs of dirt getting in to the shock.
It's not that it adds side loads, that's a fallacy which people presume because of the asymmetric frame design.I really struggle to see how someone as switched on and experienced as Spesh can design a linkage which adds such excessive side loads.
Sorry, my bad. I thought you meant side as in horizontal , rather than side - well, any lateral forceIf a bike is applying enough perpendicular force to a shock shaft that it snaps clean off, thats a side load however it's termed.
You could have a shock 3 feet long, if there was no side load the force would simply travel up the shock for the can/spring to do it's job. There shouldn't be any excessive leverage (side load) anywhere.
I accept that the thick shafts of air cans can deal with it better, I am just surprised at the amount of side load there is present in the Levo setup, whether it's caused by the yoke, the (non) offset symmetry or whatever else is contributing to it.
If you try to compress anything the forces will also try to go sideways, making it longer adds more leverage to it. If the shocks not designed for that kind of installation, it will fail. It's not a fault of the design, it's a fault of using the wrong shock with the design.
