Answered Do Shimano ME7 Spd shoes work with crankbrothers Mallet DH Pedals?
Feb 5, 2019
163
29
Wales
So I followed the instructions for both, but could not get them to clip in and out. I have tried adding a shim to get them to work with each other. I don’t think it helps with the fact the cleat holders are held together to the shoe via a sticker. I have put the cleat in the most forward position for efficiency, but it’s still super difficult to clip in and out. In fact, I have to take the shoes off and push with a lot of effort to clip in, and the shoes have to come off to get off the bike, and pull them off with a lot of effort as well.
I’ve watched many YouTube videos but they haven’t helped.
Comments like, “wear flats” I do not need, because I am too invested monetarily, and would like a more fitting solution.
ccrdave
1,421
1,125
uk
Me7 are designed to work with shimano pedals hence the channel to guide the cleat into the clip-in. My guess is the crank bros clip-in is a bit wide for the channel hence your difficulty. When i used crank bros pedals (not for very long) i found shoes with a flatish sole worked best
Feb 5, 2019
163
29
Wales
Yeah I thought as much (change the shoe or change the pedal). When I bought both I was blinded by top reviews.
Seeming as the shoes cost me more (they both RRP at roughly the same price though), I am leaning to getting Shimano pedals. Any recommendations on this?
All the Shimano pedals are good - the only reason to pay for a top end one is weight saving - I believe the likes of HT are also Shimano compatible, along with several other brands
6,519
5,001
I experienced similar problems with my Cube SPD shoes used with Shimano pedals. It was as an earlier post explained the fact that the cleats fitted too deeply into the sole of the shoe. Putting some shims between the cleat and its "home" in the sole of the shoe would have worked but I opted to reduce the depth of the tread pattern on the shoe. After all of that faff, I decided I did not like being clipped in or wearing dutch clogs for shoes so stuck to flats :eek:
552K
