Cube Reaction 750
Loxa
7
Hi,
Abit of a random question, just recieved a Cube Reaction Hybrid Pro today and noticed that some plastic on the headset is cracked and squeezed in. I will also add pictures.
Hattori-Hanzo
395
508
Common problem with a lot of Cubes that come fitted with plastic caps that can split.
I replaced mine with an alloy one straight away.
Loxa
7
Ahh ok, which one did you go for? I will also replace it with a better one. Strange is was plastic in the first place.
Hattori-Hanzo
395
508
Cost cutting I suspect or to reduce damage by over tightening, designed to fail 🤷‍♂️ cheaper than replacing bearings.
I just replaced mine with a generic alloy one, you don't see it as I have the kiox covering it.
547K
