Changing brakes on Kenevo
Leeky1
26
17
Shropshire
Hi all
Not happy with my Code R’s on my new Kenevo. Love the bike but no confidence with the brakes. Going to change them for hopes, but when cutting my bars down today I have realised the dropper post and gears all seem part of the SRAM code levers. Will I need any additional brackets when I purchase the hopes?
Many thanks
Sean
Mcharza
E*POWAH BOSS
Aug 10, 2018
2,612
5,357
Helsinki, Finland
I changed levers to Code RSC and rotors to Galfer. Brakes are now good and no need to change anymore.
Those original Sram Centerline rotors are really bad.
RustyIron
1,795
2,763
La Habra, California
It sounds like you have SRAM's Matchmaker clamps. Other companies make similar products, including Hope. The supposed benefit is that you get to "clean up" your cockpit by using fewer clamps. That might indeed be true. You need to decide whether you prefer the "clean" look, or whether you'd rather install individual clamps that allow you to adjust the location of each control to be exactly where you want it.
One of my bikes has discrete clamps. The other has a discrete shifter clamp, and the dropper lever is integrated with the brake clamp. You can get no-name clamps fairly economically.
Leeky1
26
17
Shropshire
Thankyou. I like the clean look I will look at the hope ones. Thanks for your help
552K
