Canyon Spectral:On Smashpot conversion
RoJo
282
236
Ran smashpot on 36, Lyrik and now Zeb. Best upgrade ever (after a dropper post 😉), I'm 60kg btw.
Firstly you'll notice a massive improvement in small bump compliance, and you can either pocket this or increase the spring rate and trade a little bit of this suppleness improvement for mid stroke support. Then adjust the hydraulic bottom out to suit your riding style.
Apart from really low friction, this upgrade gets rid of the imperfections in the air spring curve which can cause these forks with air springs to either dive through mid stroke if you are running soft or never reach full travel if you are running with more pressure.
Can't recommend smashpot highly enough. I've been pestering Vorsprung for a Boxxer smashpot upgrade because honestly my Zeb feels embarrassing better than my Boxxer now.
etoni
442
3,906
Thun Switzerland
i ride smashpot in a 36 with grip2 damper 2024 its a damper between grip2 2023 and the new gripx2, there are only two damper piece in switzlerland.. this travel feeling is sick!
574K
