Hi, a have a 2022 expert coming soon, and I have a set of mt7 witch I will put on it.
But I need a but of help to get the correct adaptors.
For the frame is it 180->203mm adaptors, or some thing else?
Thanks! We will see if the qm44 is correct. Hope the frame is a 180 rear thenI believe you'll need a Magura QM44 adapter (180-203) on the rear for 203mm rotors.
As @RebornRider says, you'll need a different adapter for 220mm rotors.
I use a QM45 on the front (180-220 and Fox 36) and QM44 on the rear (180-203 Levo frame).
Yes, it’ 180 rear, so you need +23 adapter to mount 203mm diskThanks! We will see if the qm44 is correct. Hope the frame is a 180 rear then
Luca
I have 220mm rotors and QM-45 adapters.
Yes I used QM-45 adapters and 220 mm rotors front and rear. Simple bolt-on with no clearance issues on my alloy rear triangle.Ok for the front, but QM-45 also to fit 220 rear?
Yes fully retracted. I Will need to play around to find the best alignment.Are you sure that the pistons were *fully* retracted when you installed the new pads and rotors?
