Ok it's just that I get out quite a lot so like it to be charged enough for a decent spin at 40 percent it would be a bit limiting for me , but was wary about charging it every time from that level....agree...except I only charge to 100% if I am going on a long ride, otherwise I charge to c 80%. Regardless I charge to 100 % occasionally and leave overnight before use.
The number of times you initiate a charge has no bearing on life - charging it 10 times in 10% increments is exactly the same as charging from fully flat to fully charged up once. Based on what you have stated about your usage pattern I would suggest you follow @Mikerb ‘s advice and charge to 70-80% each time after use if you want to maximise the cycle life.Ok it's just that I get out quite a lot so like it to be charged enough for a decent spin at 40 percent it would be a bit limiting for me, but was wary about charging it every time from that level.
No, that’s definitely incorrect (though EMBN have stated this on more than one occasion). Storage at elevated state of charge for extended periods will knacker your battery well before it reaches it’s maximum potential cycle life. 30-70% charge is where it needs to be if leaving for any longer than 24-48hrs between rides.I heard it’s actually good to charge to 100% after every ride. Something about good for cells to have full charge. So that’s what I do. And it’s always ready to go.
Thanks folks some useful info from all comments. Going to look at the links put up know I won't understand half of it but has to be done.There is no dispute that charging to 100% when full range is not likely to be needed is not the best way to prolong battery health. I think the confusion ...if there is any....is due to advice to fully charge before a ride to avoid range anxiety. If you know your ride will only use 50% then just charge to 80%. That also leaves 30% which is ideal for leaving the bike unused
So I've been out today 65 when i went out 15 percent left after ride so i will take it up to 70 tonight but intending a longer run Sunday so top it up tomorrow night or on Sunday morning.All you really need to understand is that the final stage of charging is used by the BMS to balance the voltage in each cell. That is necessary occasionally but generates a lot of heat in some of the cells. I only charge to 100% the night before a long ride. For my normal rides of 2 or 3 hours I charge to about 80%.
Good to know! Thanks!No, that’s definitely incorrect (though EMBN have stated this on more than one occasion). Storage at elevated state of charge for extended periods will knacker your battery well before it reaches it’s maximum potential cycle life. 30-70% charge is where it needs to be if leaving for any longer than 24-48hrs between rides.
Lots of threads on this topic are available in the forum, have a gander...
Battery care/management - EMTB Forums
Loss in battery life - EMTB Forums
Battery Management - EMTB Forums
...and here's some external resources explaining the factors that influence cycle life, capacity degradation and power density over time...
How to Prolong Lithium-based Batteries - Battery University
Three Ways That Lithium Dendrites Grow
They were doing so well until they got to the end......Not sure about the different brands, but Rocky Mountain people said:
In general, Lithium Ion batteries will last the longest with smaller cycles.
For example, 200 half cycles, will put slightly less stress on the cells than 100 full cycles.
This effect is quite marginal however.
Our system is designed to keep the battery within its safe parameters at both full and empty. At the top end, our charger regulates the current to allow the maximum amount of energy per cell, without over charging. At the bottom end the motor controller is dictating the cutoff or where ‘empty’ is, and rolling off motor current accordingly to keep the cells safe.
Another note would be regarding temperature. Sustained high current draw at high temperature could shorten the life of the cells (ie hill repeats in the dessert), however the battery’s internal management system has a temperature failsafe to stop the battery from supplying current if it is too hot.
It doesn’t hurt to keep the battery fully charged, and is far more convenient to have a full bike ready to ride. If the battery is left for months on end without use, then a top up charge is a good idea.
Whilst battery health figures can enable rough comparison of packs of the same type from the same manufacturer, their absolute values are of little use since we have no idea how they are calculated. The only way to tell if a battery is truly healthy is to conduct a number of controlled tests on it, which normal involve a full charge/discharge cycle.For what it's worth, I've been charging the battery on my Giant Road-E bike after every ride for over 1 1/2 yrs, and the battery health via the app says 99%.
