Bafang M510 Conroller Replacement
sparkyb
West Yorkshire England
Hi I have an Error 36 on my Vittus E-Mythique, which I believe means I need a new controller. I can source the controller but I think I need to use the BESST software and the BESST programming tool to calibrate the new controller. I also think I need credentials to use the software.
I just wanted to post in here to see if I am on the correct path with this fix?
Also the motor I have is 36V, 25 KMPH and I wondered if it was an option for me to purchase a different controller that isn't restricted to 25 KMPH.
Any help on this would be much appreciated.
Mark
20,794
Mark
Hi !
There's short and long answers, but you're probably best absorbing knowledge on the way so you know what you're dealing with.
This threads a good starting point and there's several others :
Cheers.
554K
