I recently converted my bike to tubeless which went well and have been out 3 times since the conversion without problems.
Today though I got a puncture and it failed to seal it. The tyre was covered in mud so couldn't see properly but it appeared to be a cut in the running surface of the tyre about 3mm long but not wide, just looked like something had pierced the tyre.
Am I expecting to much from the sealant which was Stans brand. The fluid is very thin, like water, is this normal. I did shake the bottle before I put it in the tyre as instructed. I remember years ago putting Slime in my tubes and this was a much thicker solution.
So I ended up getting covered in the bloody stuff while putting an inner tube in so I could continue the ride.
At the moment I'm wondering whether to put tubes back in as if the sealant doesn't work then it's pointless ,it does work I know as I've seen some impressive videos on YouTube, Daily Mountain Biker's being a very tough test.
Are there better makes of sealant to use? I was heading out to Berkshire Bikes to have look round anyway and they said to try the Muc Off sealant but I guess they would as they sell it
So have I done something wrong or just been really unlucky with my first puncture?
Someone was just taking delivery of a new Turbo Levo and they had driven all the way down from Kendal so the shop must be good.
Bit more commission for you Rob? I bought a couple of bits while I was there and mentioned you but didn't get any discount lol.
All the best everyone.
