Allmtn 7 deore xt rear mech
avman
34
hull
Hi all another day another issue
my deore xt 12 speed rear mech gets clogged up really badly with grass and trail bits n Bob’s on every ride more than any other bike/mech combo I have had I the last 30 years of mountain biking. I’m not sure it’s related to the haibike or a general issue with the xt mech.
Last ride out I’ve now have a bent cage on the mech and I’m not sure how it’s happened possible a stick getting caught in the mech. Making for a replacement mech.
Has anyone else had similar issues.
Cheers
Jon
pampmyride
124
161
Sussex Massif
Not noticed clogging more than other mechs. But mine broke (stick) on my first ride. I found the cheapest shimano mech & swapped the posh bits over. That's now had over 1000 miles on it - allmtn7 rider here too.
avman
34
hull
Cheers for the info
I think it sits low to the ground compared to sram GXD 11 speed.
The annoying thing is I was away and hoping to do a fair few rides in the new forest.
flash
1,050
986
Wamberal, NSW Australia
As cassettes get closer to having dinner plates for granny gears then mech cages will get longer A deore mech cage might be stronger (steel) and has the same performance. There's also a 46 tooth option and shorter cage mech. Otherwise dropping to 10 speed (transmission change) and a shorter cage mech.
Gordon
pkos
Gdansk
I just had to replace my rear mech, after 1y (2000km) in AllMtn 7. It got so many hits that making it work was virtually impossible. Not sure but my impression is due to mullet 27.5 rear wheel and long trolley the mech is very close to the ground. Definitely closers than on 29' wheel.
552K
