30t chainring on Levo?
Jeff McD
349
381
Kona, Hawaii
I know 32 tooth is the smallest chainring that specialized recommends for levo. However, looking for a slightly lower gearing for ultra steep trails. Anyone successfully fit a 30 tooth chainring? I remember reading years ago that it was still possible to fit this with some workaround.
lumpy
🚁 CHOPPER 🚁
Nov 26, 2018
469
441
SF Bay Area
I put this on last year and love it. It makes climbing much better and is a harder steel than the stock Praxis. Bolts right on with stock hardware. Can even get it on w/out removing crank arm!
Jeff McD
349
381
Kona, Hawaii
Thanks guys. Appreciate the help. Got to go smaller CR since no rotator cuff tendons right shoulder/multiple bilateral shoulder injuries with weak shoulders making it hard to lift bike over gates on our rides. Otherwise I would've got the cassette.
21,375
It's at times like that you need the Brose "Turbo" combined with the Shimano "boost" to give you KITT's (knight rider) "Turbo Boost" to :
When used in combination with the Trajectory Guidance System and a pair of front-mounted rocket motors, the car could "jump" 40 feet into the air to avoid obstacles.
No more lifting over gates ! .. Or just buy a Kenevo .. we ride through gates . ;)o_O:LOL:
Jeff McD
349
381
Kona, Hawaii
Yikes, Kenevo no can. You should hear the cackling as I'm wobbling to get the bike over the gate. Have to force myself to do it since I go up alone to do trail work frequently. But sometimes I almost fall over before I get it over the other side. Finally bit the bullet and bought an S Works model since a coworker wanted my Comp. That's a lot more manageable & with a light cross country wheelset no more wobbling haha. Finally, a benefit to being skinny.
575K
