22 Gen 3 Levo - The cleaned posts.
Status
Not open for further replies.
Citylad77
69
113
Midlands
AFAIK 2020 as well.
My New last July 20 S works below only had the 2 year warranty.
21,128
I've just realised that basically this bike is a YT Decoy Elite. Now I cant unsee it.
If you check all the numbers of the setup with the Head at 65 degrees (same as 2019 Kenevo) everything else is within 0.2 degrees/4mm of a similar sized 2019 Kenevo - except reach and wheelbase which are longer on this unless you went exactly between sizes - then everything's pretty much identical.
Proving my theory ( :ROFLMAO: ) that the 2019 Kenevo is the ultimate bike :) ..
And I guess that YT also copied the 2019 Kenevo ?
#Very Bias !
21,128
S-works frame? Smlxl sizing? Looks like a draft.
That was me miss typing (one handed), should have been s1-s3 , just noticed all of that is already in post #2 anyway so @Moderator can you delete my post please, it's junk.
I think the s-works frame relates to the point that it's FACT-11 carbon. So the s-works,pro and expert all get the s-works fact 11 carbon frame. Normally the expert gets the FACT-9 carbon frame - so the Experts even more of an upgrade over the 2021 model.
johnscioscia
121
28
Tampa
My question is can my LBS retro fit the new TCU display mastermind into my 2021 turbo levo expert??? PS I love my 2021 performs flawlessly and silently at all times!! I even added AXS upgrade kit and Bike Wrapped it so there is nothing I desire other than that new TCU!!
21,128
replied on the other thread ..so when that gets moved here .. I'll look like I'm talking to myself ..
But yes.. compatibility wise. you can use the MTCU .
Availability wise, unfortunately not, at present they only have enough for the new bikes.
johnscioscia
121
28
Tampa
I hope the motor is not changre
No the frames totally new, and the motors had some changes too. Its a whole new bike
I hope they did not change the motor or battery that much if at all, why?? My 2021 turbo levo experts battery is silent, The belt is silent and pulls very very strong!! I do want the new TCU though if I can do that?
Dod Colony
53
49
The new TCU looks like a nice upgrade but might be impossible to source and probably be way overpriced.
I've got the same bike as you and fitted the Turbo Connect Display, it's not as fancy looking, more like an old school bike computer but it connects wirelessly and displays quite a lot of info including battery life as a percentage.
johnscioscia
121
28
Tampa
I got my answer:: I just watched a video with specialized bike designer interviewed. I am happy to say that the new 2022 has the same motor "2.1" as the 2021. Yes the belt is a little thicker but it is the same belt that came on the 2021 models. We just wanted to call it the 2.2 motor instead of the 2.1 just so it is easy to monitor. They had to rely on the serial # alone to determine if the motors on the 2020 and 2021"s had the new belts and all updates. So NO CHANGE IN MOTOR from the 2021 to the 2022. Battery is the same too. I can assure everyone that my 2021 motor is smooth as gless and silent too as weill be all the 2022 models going forward. So all I need now is the new TCU and Im golden!
Loamranger
205
100
U.K.
My understanding from the Mtbr video the new TCU will be made available as a separate item when they have enough in stock.
Status
571K
