2023 Orbea Wild
Chicane
396
360
SoCal
I thought that at first - but then noticed the fork and shock are only the 'Performance' level. Maybe things have changed, but I once bought a bike with 'Performance' (ie bottom of the range) level forks - they were terrible. Never again!
Same. The M10 spec is a huge downgrade from the original Rise M10 at 8k prior to the duel price increase. 6120 brakes, really?
Freeforester
38
37
Grampian
This might be a bit left-field, but for anyone looking for a solution for keeping the ‘love (for your ebike) in a cold climate’ it might be possible to use something like this?
I’m guessing it’s more about not having a place with a power supply in which to plug in a heating element, frost stat or wrap blanket. A non-electric paraffin or gas space heater is going to be a costly solution - for those in larger conurbations, they might consider the (albeit less convenient) possibility of sharing a warm secure storage room with some other/s, or making an arrangement with any sympathetic employer, but I get too the inconvenience this suggestion implies.
Mar 10, 2022
74
39
United Kingdom
I love the idea of fixed battery but my wife won't :/
35 forks.. ouch..
I love the brand but It does grind my gears that Orbea never lists weights with the whole "oh you have to ride the bike to feel it" and then they race on about how the top model only weighs in at xxx.
yorkshire89
468
663
North Yorkshire
So at what point should the battery be stored or charged indoors? What is the temperature range or high and low for potential problems?
also, what is the over run on the standard Bosch motor? The race having a 2 meter over run may be great in an experts hands for racing, but for us mortals, that could be dangerous.
Bosch recommend storing the battery between 0-20degC, ideally at a constant room temp of 20, and between 30-60% charge for best battery life.
2m is the maximum overrun an ebike can have by EU regs. I'm not sure if this is dependant on speed though. The standard Gen 4 feels like you get about 0.5-1 second.
Mikey B MTB
Hi Mike.
The mechanics can change out the batteries in about 15-20 mins (they swapped mine from 750 to 625 at the trails. I assume that they will have mechanics at the pits and be able to swap out fairly quick.
Fair enough, it is easy, it's only 6 bolts, lots of spares and a team. It's just not very practical for your average racer titting about in a car park. They must know what they are doing, il keep quiet 🤫
Donamici
139
171
Ireland
I would have taken a slight weight increase to have a removable battery and associated gubbins, they have really narrowed the market for this as a result, pity. Also amazing that Giant will give you a decent Fox 38 on the Reign when Orbea only give you a very average 35.
But great to see lighter full fats arriving, no great gain on the trails but much appreciated when you have to hump it over a fence!
Rob Rides EMTB
Administrator
Staff member
6,290
13,835
Surrey, UK
Bike is slacker than advertised!
Orbea vs Decoy
5735B4B4-7C68-4039-8F2A-6902490DC363.jpeg CF8FA9B7-2A51-4063-B2AA-64D5EAB68635.jpeg
Rob Rides EMTB
Administrator
Staff member
6,290
13,835
Surrey, UK
FYI on Fork.
160mm comes with the 68HT crown (fat crown)
170mm comes with 58mm crown (regular crown). Both fit fine. Slight step down on the 58 HT (170mm Fork)
Dirtnvert
1,471
1,709
BC Canada
Orbea vs Decoy
View attachment 101668 View attachment 101669
Hmmm, what decoy is this? "Soon to be released can't say" decoy?
I'd be off to the lbs to order an aluminium wild w my pic of sudpension. It might be BOTY except for some reason theyre another company that doesnt have a flip chip to mullet it. I dont think a lot of people that are after small, medium, and some large are best suited to full 9er on an enduro emtb. All the great details and design they put into this and no flip chip. Boggles the mind. Same with the voima
Scout762
Utah
35 forks.. ouch..
This irks me also. If you are going to rave about weight, please list it. We know that specs/components change things, but a benchmark would be helpful.
JStrube
290
219
Atwater, CA
Ouch, my garage never freezes, but the 20C top range hurts... We hit 40C regularly in the summer here in California... 20C is about 68F.
Zave
41
17
Surrey England
What is the sizing on the 2023 v 2022. I tried a 2022 in XL, it was too big.
2023 has same reach in L as last years XLat 580 reach. But angles are different.
Current bike is 450 reach but more trail, less enduro angles
I'm 5'10 long legged.
jbrown15
818
690
Chilliwack, Canada
At 5'10" I would personally suggest a new large frame, unless you prefer the feel of a smaller bike.
MarkH
234
265
Manchester
The Fox 'Performance elite' range have the same internals as fox 'Factory' less the kashima, so essentially the same as the top of the range in all but looks.
Edit - corrected above - I should know that as have the Elite's on my Decoy/
74
39
United Kingdom
The Fox 'Performance' range have the same internals as fox 'Factory' less the kashima, so essentially the same as the top of the range in all but looks.
Performance elite, the performance just hast a a grip damper and the elite has the grip2.
Ridden all 3 would not pay through my nose for the elite or the factory.
mxh
113
50
As said above, that's incorrect. It's 'Performance Elite' that are the same as 'Factory', less the Kashima.
'Performance' are a level (or in my experience, more!) down.
Mar 10, 2022
74
39
United Kingdom
My wives Canyon spectral:eek:n has a Rockshox Yari tbh. It's enough for for around here I would love to see something like that specced on the Orbea bikes. The 35 forks are in my opinion a throw away part on a bike that is this capable.
brizi2003
237
149
Whickham, Newcastle upon Tyne
From 20.8KG
Brilliant review video Rob! Looks like the right direction for full fat ebikes. Lighter, bigger battery range & well integrated controls. Orbea bikes look good too! I did laugh a bit now that Bosch have finally managed to do a neat handlebar control - something Specialized have had for more than 5 years!! A bit out of my price point though!!! So I'll just stick to my 2018 Kenevo for now!
568K
