2022+ DEVINCI THREAD
paulcanadian
18
10
Bragg Creek, Canada
Since it is very hard to find any info on the Devinci E-Troy or E-Spartan, I will start this up.
I bought a 2022 E-Troy, size large (I am 180cm), Deore build (for $8200 CAD). I rode it with the 160 36 for a week, then swapped to a 170mm 38 which really brought the bike to life. The bike also came factory with MT7 brakes, which was a nice bonus! The bike totally rips! Longer chainstay and WB make it very stable. Why Troy over Spartan? The Troy was in the shop and I could ride it around to test it out. The Spartan was not, and I was worreid it would feel much too cumbersome with 180-170 travel. That is a lot of fork!
I was looking at the Troy frame though, and the Spartan frame... and I am very convinced that they are the same frame but with different forks (180- vs 160)and more shock stroke (65 vs 57.5) to bump the rear travel up to 170mm. All the geo numbers are the same, except for anything that would be effected by the suspension changes (HA, reach, STA, ect). So I pulled the air can off the 57.5mm stroke Float X shock and removed all the spacers to make it a full 65 mm stroke shock (FYI- the float X stroke is adjustable with spacers. 57.5 stroke shock is the same shock as the 65 stroke). With the spacers removed, the bike can fully compress without seatstay contact or binding. Is it now a spartan? What I ended up doing is making it a 62.5mm stroke, calculating to about 163mm rear travel.
I have dubbed it the Devinci Centaur - half Troy half Spartan. A 170-163 beast!
FYI - Check engine mount bolts... add threadlock if not already applied (mine had none and the bolts backed out).
These are good e-bikes.
jbrown15
742
629
Chilliwack, Canada
The e-Troy and e-Spartan frames have different top tub lengths. Would they not be the same if they were the same frames?
Actually, after using a frame geo calculator and plugging in the numbers you could be right. They would be the exact same frame.
paulcanadian
18
10
Bragg Creek, Canada
Here’s a pic. Changed wheel sets to a more robust set, DH tires with inserts.
If they are the same frame, this makes for a pretty versatile bike! I measure a 64.1 HA as it sits.
jbrown15
742
629
Chilliwack, Canada
Here’s the e-Spartan I built up for my buddy. Changed out the fork, bars, stem and grips. Swapped out the crappy stock dropper post lever for a OneUp, new fork decals to get rid of the orange and put a set of black Flo brake levers on.
48C0C881-F166-40C4-B319-5AAC572013EC.jpeg E8693C1B-F478-48CD-9169-51DDBF55FC4A.jpeg
paulcanadian
18
10
Bragg Creek, Canada
Also check those engine mount bolts for locktite. I had a bolt back out right into the cranks (1 week of riding). They were torqued by the shop but not checked for locktite.
jbrown15
742
629
Chilliwack, Canada
He loves it, he sold his Husky MC7 to get this bike. I retorqued and locktited the motor bolts so hopefully no issues with that. I also installed a Ride Wrap on it for him.
We swapped out the Grip2 dampener from his fork on his Husky and installed it into the fork the fork on this bike. So now the bike has a Performance Elite fork instead of just a Performance 38. His next upgrade will be some carbon WeAreOne wheels.
530K
