BOSCH gen 4 CX - Power output stop....
varenummerdk
Denmark
1 Year old 2024 Canyon Strive ON BOSCH gen 4 motor.
Hope someone can help me. This is a very long process. Since July 2024, Canyon has tried together with Bosch to get my bike running. It has been at Canyon 4 times now. The problem is that the bike power, from the motor stops providing assistance, power, ETC when the bike hits 15-16 kph, (I live in the EU). It is so clear to feel that the bike becomes heavy and no power output from the motor. AT 15-16 kph... IT STOPS.
They have changed all cables, battery and recreated a new Bosch file for the motor. It only helped 30 km run, the bike was so crazy that I could clearly feel the difference from the old one to the new super fast bike that stopped at 25kph. SO SO insane feeling... Thats how it should run.
But now we are back again. Same issue, And what I think is totally strange , is that if I turn off the bike and close the bosch flow app. And start the bike on the button, and open the bosch flow app. It all syncs up, and then the bike is full blast again. Then I can ride 10 km, then I'm back to no power in the engine. It stops giving output in power and assistance at 15-16 kph. In all modes, Tour+, Emtb, Race..
But they just keep resetting the bike. What should I do ? , does anyone know what it could be?. The bike becomes totally heavy and pedals at 15-16 kph. And it is set in Bosch system diagnose for EU 25 kph.
I have tried other bikes with same system - The smart system, those bikes runs like a dream, fast and they tried my bike to, they say : SOMETHING IS STOPPING the bike in the engine, they can feel it too, like for big. 4 guys have tried, and same words they say...
My bike have many errors, here are just a few :
113161
112100
142001
120102
110000
15201
503012
620012
903005
DieBoy
162
257
EU
Some of those error codes are wild, e.g.
620012
Your battery has detected a short circuit.
And apparently 113161 is no longer in use, have you done a firmware update since?
At a completely wild guess, I'd say the motor is overheating at higher speeds and switching itself off, but that's pure speculation and as you're in DK too hot isn't the first problem that comes to mind.
I'd suggest you demand a replacement motor, as this is the only thing left not yet swapped out, and this problem really shouldn't be happening. You're still within the 2 year statutory warranty period.
varenummerdk
Denmark
Firmware and total updated on app.
They won’t replace the motor. 👎
6,857
5,306
you say it has been in for repair 4 times.....but what did they do on those occasions? Given the issue seems mostly about motor power cutting out before the programmed shut off speed of 25kph surely they have changed the speed sensor and ensured the firmware is up to date?? Regardless I agree with the a bove, if they have failed 4 times to make the bike useable you should return it as not it for purpose.
varenummerdk
Denmark
They have change the wires, cables. Next new battery, last again a wire. They do WHAT bosch saying to them eveytime. The speed sensor are at the backwheel, the one , the new that sits on the valve. ALL firmware are 100% up to date. They dont get error from speed sensor, so for me, it must be a sensor inside the engine, that wont will give a error, but are defect anyway. They say i cant return my bike. And bosch wont replace the engine. So iam fucked.....Every time the diagnose says error, they just delete them and reset bike
TSL
Poland
1-річний Canyon Strive 2024 НА Двигуні BOSCH gen 4.
Сподіваюся, хтось може мені допомогти. Це дуже довгий процес. З липня 2024 року Canyon разом із Bosch намагаються запустити мій велосипед. Він був у Каньйоні вже 4 рази. Проблема полягає в тому, що потужність велосипеда від двигуна перестає надавати допомогу, живлення тощо, коли велосипед досягає 15-16 км/год (я живу в ЄС). Настільки чітко відчувається, що велосипед стає важким, а мотор не видає жодної потужності. НА 15-16 км/год... ЗУПИНЯЄТЬСЯ.
Вони змінили всі кабелі, батарею та відтворили новий файл Bosch для двигуна. Це допомогло пробігти лише 30 км, велосипед був настільки божевільним, що я чітко відчув різницю між старим і новим супершвидким велосипедом, який зупинявся на 25 км/год. ТАКЕ ТАКЕ божевільне відчуття... Ось як це має працювати.
Але тепер ми знову повернулися. Та сама проблема. І що я вважаю абсолютно дивним, так це те, що якщо я вимкну велосипед і закрию програму bosch flow. І запустіть велосипед кнопкою, і відкрийте додаток bosch flow. Все синхронізується, а потім велосипед знову працює на повну потужність. Тоді я зможу проїхати 10 км, а потім у мене знову зникне живлення двигуна. Він перестає видавати потужність і допомогу на 15-16 км/год. У всіх режимах, Tour+, Emtb, Race..
Але вони просто продовжують перезавантажувати велосипед. Що мені робити? , хтось знає, що це може бути?. Велосипед стає зовсім важким і крутить педалі зі швидкістю 15-16 км/год. І це встановлено в системі діагностики Bosch для ЄС 25 км/год.
Я пробував інші велосипеди з тією самою системою - розумна система, ці велосипеди їдуть як мрія, швидко, і вони спробували мій велосипед, вони сказали: ЩОСЬ ЗУПИНЯЄ велосипед у двигуні, вони також відчувають це, як для великих. 4 хлопця пробували, і вони кажуть однаково...
Мій велосипед має багато помилок, ось лише деякі:
113161
112100
142001
120102
110000
15201
503012
620012
903005
Привіт, я працюю техніком з обслуговування електровелосипедів у Кракові, Польща. Минулого тижня у нас була така ж ситуація, клієнт прийшов до нас з велосипедом GHOST, який не допоміг йому після 15 км, і він їхав так майже рік, не розуміючи, в чому причина, коли ми підключили його до нашого програмного забезпечення Bosch, була інформація, що двигун не налаштований, ми зв’язалися з Bosch, який допоміг нам зв’язатися з GHOST, і вони надіслали нам оновлення для двигуна з параметрами цього велосипеда. Ми оновили велосипед, і він продовжує працювати як слід, тому зауважте, що якщо ви отримуєте багато помилок, це проблема з правильним програмуванням двигуна
ValActionT 750
32
12
Escondido
Then return the bike and demand your money back as you are entitled to under EU consumer protection laws.
A good company would give you a new bike at this point, definitely a new motor. IDK how it is in your Country but in sue happy USA it’s small claims time, (basically sueing someone for smaller amount of money. Also tell them you’ll give bad reviews up their arse.Post on YouTube Yelp all the ebIke review platforms. That’s how we Yanks roll. Good luck man.
irie
3,250
3,389
Chichester, W.Sussex, UK
Under EU (and UK) law you are entitled to return the goods for a full refund.
It's best to do this first then only after receiving the full refund decide what to do next. Otherwise you risk getting into the partial refund and delaying tactics game.
varenummerdk
Denmark
Wprowadzili nowy plik do silnika z centrali Canyon. Nic to nie pomogło. To samo co wcześniej..
TSL
Poland
Привіт, я працюю техніком з обслуговування електровелосипедів у Кракові, Польща. Минулого тижня у нас виникла така ситуація після того, як клієнт прийшов до нас з велосипедом GHOST, який не допоміг йому 15 км, і він пройшов майже рік, не розуміючи, чому, коли ми підключили його до нашого програмного забезпечення Bosch, була інформація, що двигун не налаштований, ми зв'язалися з Bosch, який допоміг нам зв'язатися з GHOST, і вони відмовилися замінити двигун з цими параметрами. велосипеда. Ми оновили велосипед, і він продовжує працювати як слід, тому зауважте, що якщо ви випустите багато помилок, це проблема з правильним програмуванням двигуна
Привіт, я працюю техніком з обслуговування електровелосипедів у Кракові, Польща. Минулого тижня у нас була така ж ситуація після того, як клієнт прийшов до нас з велосипедом GHOST, який не допоміг йому 15 км, і він проїхав майже рік, не розуміючи, чому, коли ми підключили його до нашого програмного забезпечення Bosch, була інформація, що двигун не налаштований, ми зв'язалися з Bosch, який допоміг нам зв'язатися з GHOST, і вони відмовилися нам замінити двигун з цими параметрами. велосипеда. Ми оновили велосипед, і він продовжує працювати як слід, тому зауважте, що якщо ви отримаєте багато помилок, це проблема з правильним програмуванням двигуна
Д
Ja robiłem to przez program Bosch Best Tool 3. I wszystko się udało
579K
