Spectral On:Fly vs Decoy SN vs Tempo Power
Larsey
38
39
MN
I am looking at trying a mid-power this spring. I like the Spectral On:Fly, Decoy SN or possibly Tempo Power.
Mostly flow trail and small elevation. 59 y/o that has been riding forever.
Cons:
YT seems like good company in US but iffy motor (rode shuttle SL with no issues/enjoyed power output).
Canyon seems questionable in US but fairly dependable motor (rode a Fuel EXe and power was good but battery a little small)
Commencal, no clue as a company (I emailed twice with no response) I like the look of the Tempo best even being Alloy. Rode the Bosch on a Fluid VLT and it is definitely noisy compared to others but more power (if you pedal at higher cadence). Also the most expensive of the 3. But if you like something you will probably ride it more
Any thoughts from actual experience with above companies or bikes.
I can also get a great deal on a Norco Fluid VLT C1 but still more than the DTC.
Thanks for any insight (long winter here and probably over thinking it). I can pretty much do any work on bike so not concerned about upkeep
JP-NZ
1,344
1,056
Christchurch - New Zealand
Tempo no clue as a company (I emailed twice with no response) Like the look the best even being Alloy. Rode the Bosch on a Fluid VLT and it is definitely noisy compared to others but more power (if you pedal at higher cadence). Also the most expensive of the 3. But if you like something you will probably ride it more
Are you talking about Commencal here? If so Tempo is the model not the brand. Or another brand of emtb I've never heard of?
CarolinaCrawler
290
297
North Carolina
Another one to look at if you like the bosch and aluminum bikes is the Marin Rift Zone EL. I'm very interested in the bike but there's not much out there other than the typical media reviews.
Larsey
38
39
MN
Sounds like the Transition Regulator is going to drop soon. Either 55nm SX with 400wh or 85nm CX5 with 600wh. Could be an intriguing option.
I wonder how many bikes going forward will utilize one frame with 2 motor options
575K
