Flow app statistics problem.
Old Codger
30
13
South Yorkshire
I’m new to this so just done 6 short rides. Statistics have recorded all the data but the map squares are empty.
Statistics are supposed to start automatically with the ride and I click the finish button at the end, sometimes holding it for over a second as Bosch recommend.
I have turned location on with the app only and also always on but with the same results. The app keeps banging on about Strava and Komoot but I don’t have either of these. I do have the OS maps, MemoryMap, Apple Maps and Google maps installed.
What am I doing wrong, what map is the app supposed to use?
Mister cube
89
57
Isle of wight
I use komoot on my kiox,works pretty well,maybe give that a go.
Old Codger
30
13
South Yorkshire
Yes it keeps pushing komoot but I use the OS 25k maps or MemoryMap for transferring GPX files to. I don’t really need statistics as I know where I’m going and how far but just thought I’d look at the flow statistics but am not impressed up to now.
Mister cube
89
57
Isle of wight
Agreed,i do a ride,i look at flow app,it says 22 miles 1 hour 30 mins
i also track on my garmin fenix 7,its says 24 miles 1 hour 15 mins
which one is correct? 🧐
Old Codger
30
13
South Yorkshire
I can trace the route on OS maps and get an accurate mileage. You could run a map wheel around a paper map to do the same. If you set the wheel circumference correctly ( I put tape on the tyre and wheel it along the ground with me sat on the bike ) then at least the display on the bike should be correct.
I know this sounds like a “dull man” thing but different tyres have different profiles and over 40 miles a little bit adds up.
575K
