Raymon Trail Ray 160e 10.0
jackamo
177
140
Any recommendations for front and rear mudguards for tarmac/road use?
Also looking at getting some slick/semi slick tyres for it. What width tyre would look least weird?
Just a cheap one for the front and I have one of these on the rear and they are actually really good
jackamo
177
140
The Crud XL fender fits the front nicely. I've got a MK2 Rear Mudhugger (LARGE) on the way
Just watch out for the velcro straps on the mk2 , they have a tendency to cut through themselves. Make sure you use the clear tape strip on your frome and if you've a old inner tube cut a strip of that to wrap the velcro strap round aswell to cushion it.
Crispy1980
16
Staffordshire
I would hope so , however website currently shows no stock . Although the one I ordered must be somewhere . They do have the trail ray 140e in stock in large , so I could consider this
PilgrimUK
16
They seem to constantly be getting new stock of the 160e so I'm sure it wouldn't be long.
Crispy1980
16
Staffordshire
Fair play to Paul’s , I called them and they knew they had messed up at close of play yesterday becuas number ls were wrong, so my actuall bike is still sitting there . Sending it out tomorrow
Crispy1980
16
Staffordshire
Haha, and now Paul’s have sorted the situation, Dx have sent it to the wrong depot , so still not arrived ! Hopefully coming Monday if they haven’t lost it that is
Proconn
Shropshire Uk
This is my first e-bike ever and I jumped at this offer as well, after not buying one for so long due to cost. First impressions (which are probably not specific to this e-mtb in particular) is that the weight is most noticeable over the front wheel when turning at low speed. It feels much more like it wants to flop over, so in some ways requires more strength in the arms initially. Once up to speed it feels like a mtb and I didn't feel particularly limited with turning agility and popping off of curbs (only tested initially in the road outside). What does feel weird though is not being able to just wheelie away or perform manuals as easily due to the weight. Turn on the assist though and the wheelie problem goes away.
The assist feels exactly as I thought it would to be honest. The only thing I would say, is that the cut off once you've reached top speed is very noticeable to me. So I don't know whether I will derestrict mine. I think the cost to do so is a complete joke. £150 in the UK roughly for a tiny little wiring harness to unlock it. Off road, it may be a non issue though. Will have to test.
In terms of this actual bike:
I went with a size Large and I am 6ft2 skinny. I feel it's the right size. I definitely couldn't ride a medium. I feel I could ride an XL but it would just feel too stretched out and barge like. I rolled the bars forward a little bit and shifted the saddle back. I think it's a good compromise in size for me in terms of being able to chuck it about vs comfort. If I really feel cramped I can always get a slightly longer stem as the stock one is 50mm I think.
Out of the box assembled by Pauls Cycles, my front brake feels very weak. Not sure why. Doesn't bite like the rear so not sure if they contaminated it. I hate the limited shifter only doing one gear at a time, unless I am being stupid? I used to have Shimano XTR on my old bike that did 4/5 gears in one sweep. I will probably upgrade that and possibly the rear derailleur if it is not a clutch one. I can't really comment on what the gears ratios are like yet as not been off road. It feels like the range would cover me both ends but hard to say for now.
First time I've had a dropper on my own bike and it's nice. I see it is cable operated so I assume it is a mechanical/sprung version? Seems quite nice. No complaints so far except that out of the box I have excess unprotected cable coming out about an inch or so at the handle bar control. Not sure why it's like that. Is it the same for you guys?
I think one thing about the heavier e-mtbs is that I probably won't obsess about chasing upgrades that are lighter since it's kind of pointless when the thing weighs so much out of the box. I will probably only convert to tubeless to help with that. Has anyone managed to do that?
I haven't read the manual yet, but with charging, do you only charge the main battery or do you have to charge up the display unit as well? I notice the display unit has a usb port as well hence why I ask.
I'm kind of mixed thoughts right now about e-mtb. I feel like I might end up missing the purity, simplicity and lightness of riding a sort of 12kg full suss MTB, but will see when I ride it in anger off road.
I’ve just received my Raymon 160 love it but unfortunately all the instruction book is in German lol.
djbobski
15
oxfordshire
Has anyone installed a speedbox 3.1 (for yamaha) on their Raymon trail ray 160e yet? I've got it here ready to install, along with some 12mm bolts (as recommended ot the HotUKdeals thread).
Can I do it without removing the crank arm?
Chady
8
West yorkshire
Hello all hope everyone's enjoying there bike. Has anyone serviced there dropper post yet?on my other bikes the collar unscrews by hand but this won't budge,i don't have a strap wrench either to try,not sure if it actually unscrews tbh.
I Don't no the brand of dropper post used so can't look up the manual.
PilgrimUK
16
Nice!! Looks like that ride was fun!
Funnily enough, just fitting my mudguards today. Which ones do you have? Did they stop the majority hitting you?
Chady
8
West yorkshire
Very fun and very muddy,the fronts a rrp proguard bolt on with the zeb adapter and the rears a mudhugger meant for the front wheel iv just fit it to the rear.They do keep the majority of mud of me at the front but not the rear my arse gets the most of that,the rear one is there to stop as much crap getting into the rear linkage and shock area.Iv also got one of them huge rear mudguards,they do a better job of keeping your rear clean but don't look very good imo.
Crispy1980
16
Staffordshire
Where did you get the adaptor kit from for the pro guard ?
576K
