Changing suspension
avman
42
16
hull
Hi all
Changes to amflow pl and was hoping to change over to factory fox front and rear shock I have a spare rear dpx2 160mm seams too long it maybe a 205mm
if you have changed over rear shock which one did you go for and how did it affect the bike.
Also I’m toying with going
factory 36 160mm grip 2
or
Factory 170mm 38 fit4
I have both to try problem is the existing headset has a weird fork crown washer I can’t get off the existing fork
Cheers
Jon.
avman
42
16
hull
it physically wont fit hence me asking what and if others have replaced the shock with, TBH i will probably leave it i was replacing it as i already had one available to me
im more intersted in the 170 38's vs the 36's 160
Weeksy
646
714
Newbury(ish)
Cheers
Jon.
At the bottom where the steerer meets the upside down U shape ?
That's called a Crown Race and makes the headset bearing 'fit' and meet correctly. You need a tool (or a screwdriver and a hammer, please don't)
flash
1,058
995
Wamberal, NSW Australia
You can easily remove the crown race by gently hammering in a stanley knife blade to start a small gap for a screw driver. The crown race also doubles as a knock block on the Amflow.
I changed my suspension to Olin’s. 160 36 up front and a coil shock. Nearly the same as my Lego. Have yet to ride the bike in anger as it arrived two days ago. Also swapped out the tyres. Assuaging max grip up frontt and DHRII rear. Tubeless. My size medium is exactly 21kg without pedals now.
Gordon
Rob Rides EMTB
Administrator
Staff member
6,296
13,868
Surrey, UK
Hi all
or
Cheers
Jon.
Hi. You need a 185x55 shock size 👍
Istari
27
13
Europe
Could someone write what is the Fox Tune ID code (probably visible on the back of the shock) of the Fox Float X Factory shock and the regular Fox Performance in Amflow?
tehviking
26
31
Erie, CO, USA
Gordon
For the Ohlins stuff, did you re-use the existing mounting hardware or did you order Ohlins mounting hardware separately? I can’t seem to find the specs for the diameter (I assume 8mm) and width for the shock mounting hardware on the non-trunnion end.
flash
1,058
995
Existing. It’s exactly the same as the fox DPX, I took off.. You might need a shock hardware removal tool.
It;s a zero mount kit. The width is the width of the standard plastic bushing inserts in the fox shock and the metal inner sleeve is the same length.
Gordon
tehviking
26
31
Erie, CO, USA
Gordon
Nice, thanks! I will see if my bearing removal kits will do or if I need a shock hardware removal tool.
Istari
27
13
Europe
Yes, it should be Fox Float X 185x55.
You should also know that bike manufacturers choose their own rear shock valving for each bike, which in the case of Amflow is as I provided in the links above:
2025 FACTORY SERIES FLOAT X
Serial number: 1146791-0034-t
Part number: 979-02-335
Description: 2025, FLOAT X, F-S, K, 2pos-Adj, Trunnion, Evol LV, AMFLOW, MTX, 185, 55, 0.4 Spacer, CS50, RL40, LMM, Rezi B60,
turandot
22
11
Spain
Thanks Istari. I can't find the website where they sell the 2025 FACTORY SERIES FLOAT X with Part number: 979-02-335
Istari
27
13
Europe
You can't buy this exact shock with valving for Amflow. You can buy another one with matching dimensions (185x55) and send it to Fox or somewhere else so they can change the valving to the ones in Amflow. It will probably cost around 70 Euro.
turandot
22
11
Spain
Now it's clear to me. Thanks Istari.
I asked to Amflow Support for custom-tuned amflow version of the FOX FLOAT X Factory and their answer was: "Currently the it is not available, you may need to consult Fox directly regarding this part."
turandot
22
11
Spain
Fox's answer to my questions:
Please see the specification for this shock below:
979-01-188 - 2025, FLOAT X, F-S, K, 2pos-Adj, Trunnion, Evol LV, FOX, AM, 185, 55, 0.4 Spacer, CS30, RL50, LMM, Rezi B40, Kashima/Grey, Neutral Logo, AM
VS
979-02-335 : 2025, FLOAT X, F-S, K, 2pos-Adj, Trunnion, Evol LV, AMFLOW, MTX, 185, 55, 0.4 Spacer, CS50, RL40, LMM, Rezi B60, Neutral, Neutral Logo,
OE
The only differences between these two shocks are in the tune they are fitted with. The Amflow OE shock uses a firmer compression, and a softer (faster) rebound tune. How much of an impact this will have depends on your riding style and your specific setup. If this shock tune does not provide the performance you are looking for, it can be re-tuned at a later date.
turandot
22
11
Spain
Another good option to change on Amflow PL Carbon: RockShox Super Deluxe Ultimate (RS-SDLX-ULT-C2), 185x55, Trunion
576K
