Experiment 2: 4x chain rotation longevity
Emteebee
25
22
Netherlands
I've started a small experiment on my Cube Stereo Hybrid, Bosch CX Performance gen4.
Wanna find out how many kms to get from a chainring/cassette and 4 chains on rotation.
Silca hot wax after every ride of 40-100kms
I started with a new set of:
  • SLX cassette with XT cogs on 5 highest gears.
  • RaceFace chainring 34t.
4 chains:
  • 1x Shimano XT M8100
  • 1x Shimano Deore M6100 (OEM standard for this bike)
  • 2x SRAM XX1
Initially started with 1x XT and an XX1 but I noticed a fast wear of the XT. I deliberately let it wear for a couple of rides to confirm it really was wearing more and more. I measured after every ride. The XX1 isn't giving an inch, it remains dead on at 0% wear.
That triggered me to compare with a Deore, just for the fun of it (and on sale for just €10). But also looking to get the most out of cassette/chainring so bought an additional XX1. So this is where I'm at now regarding kms:
  • XT: 400km = 0.10% wear
  • XX1: 500km = 0.00% wear
  • Deore: 0km
  • XX1: 0km
Motor use is by average 75% eMTB, 15% Turbo, and pretty wet and dirty mud conditions in the last months.
Will keep posted how things progress. Some things I want to learn from this:
  • Chain longevity per type?
  • Will cassette/chainring last the 4 chains?
  • Total set milage?
Chain wear data, 900km total:
Motor driving mode usage data:
(* data shown at 24-11-24 are averages as from start of measurement at 1 nov 24)
What I'm hoping to confirm is cassette/chainring can last pretty long, given I swap chains based on equal wear% so the whole set wears out evenly. I've put the XT chain on ice for now to let the others catch up on it.
I am just very curious what the optimal amount of chains per cassette/chainring is for myself for my specific conditions.
I'm well aware that I could run 10x Deore chains for the same price as 2x XX1. But that might be another experiment. Which I will not attempt btw.
Stihldog
Handheld Power Tool
4,099
5,800
Coquitlam, BC
Wanna find out how many kms to get from a chainring/cassette and 4 chains on rotation (swap based on wear). Silca hot wax after every ride of 40-100kms
4 chains:
  • 2x SRAM XX1
That triggered me to compare with a Deore, just for the fun of it (and on sale for just €10). But also looking to get the most out of cassette/chainring so bought an additional XX1. So that's where I'm at now regarding kms:
  • Deore: 0km
  • XX1: 0km
Will keep posted
Interesting experiment. The results could be helpful.
I use 3 types of chain lube. One of them is probably just olive oil …I wouldn’t know. XT cassette and 8100 Shimano chain.
But the most important thing I found was proper cadence. I’m mostly in eMTB mode and climb almost any trail. These motors can add a lot of stress to our transmission and motor components. I believe that I have extended the life of these components by using the correct cadence.
I haven’t tried the hot wax or chain-alternating method.
irie
3,241
3,380
Chichester, W.Sussex, UK
Agree with you. Mrs irie often uses very low cadence (<60) and I have to change her chain after about 600 miles. I try to keep my cadence 70+ and have to change my chain at over 1,000 miles. Both alloy Trek Rails. Also hear her crunching through the gears while I always back off a little before changing.
Edit: both Shimano XTR chains (buy them when they're on overstock discount)
Stihldog
Handheld Power Tool
4,099
5,800
Coquitlam, BC
It took us few rides but eventually she reached 70-80 cadence. That’s a huge improvement over 40. I just need to work on the crunching noise …but that’s getting better also. 👍🏻
RoJo
285
241
4 chains:
  • 2x SRAM XX1
  • Deore: 0km
  • XX1: 0km
  • Total set milage?
Fantastic experiment. Keep us all posted.
There are other results for XX1 performing well for longevity, unfortunately the original cycling tips article was taken down but here are the graphs:
Also:
10,010
@Emteebee I have long believed that the whole transmission wears at the rate of the worst component. Have an all top-end transmission and it will last absolutely ages. But put a cheap chain on it and the whole lot will wear rapidly.
Therefore, I have concerns that leaving the XT chain in there, that is already suspect will contaminate your experiment. When the XT chain is running, being worn more than the rest of the transmission, it will wear them at a faster rate.
I have already discovered for myself that high end transmission delivers longer life and posted on here to that effect.
6,851
5,299
the main differences between the cheaper/lower in the range chains and those higher up the range is the coating material used. Very often you only need move 1 step up the range ladder to get that (e.g SRAM gx toX01) whilst the actual top of the range chains often just prioritise low weight......often with hollow pins.
All steel casettes ( maybe with an alloy 12th gear) are obviously more robust than ally versions and assuming a variety of gears are used on most rides wear is distributed across up to 11 cogs......therefore casettes tend to last longer than chains.
What wears on a chain is the inner diameter of the rollers ( and possibly the pins). I reckon the chief contributer to that wear is dirt which means chain cleaning is important. I agree with the a bove that cadence is probably second on the list of contributors to wear. Given the chain is not subject to heat or rapid speeds I really do not think what lube is used makes much difference provided it is replenished regularly. (except of course to the various lube brands ££££)
Mr President
306
213
monmouth,wales
Thanks to the OP for posting his experiment
I’ve done almost 10,000 Kim’s now. All on GX chains, which know understand is not the way to go, it am currently locked into my own hot wax experiment with the GX so stuck there for a while. Typically only getting 700kms from a chain, but again that’s not a surprise given all the above information.
I’m still on third cassette.
here’s my question: I’m still on the original SRAM X Sync2 chainring 34T on Bosch Gen 4, which just seems to keep working, even though it is a bit shark toothed. I asked the mechanic at the LBS whether i should change it and he said no keep going with it until it starts to feel rough. What do you think?
Emteebee
25
22
Netherlands
I think as long as you ride current chain, keep the chainring, since they match and ride everything until worn. When you install new chain, replace chainring (and cassette) to prevent chainsuck considering you’re noticing a bit shark toothed. 10.000 it had a nice lifetime.
Chain advice: take the X01 or XX1, wil last so much longer and give you more out of cassette and chainring. My XX1 is currently at 650km and still a measured 0.00mm of wear.
Emteebee
25
22
Netherlands
Today prepping participants K3 and K4 of my experiment. A 2nd XX1 and a Deore M6100. From the last one my hopes aren’t really high, especially considering the looks of it after 10 mins of UFO drivetrain cleaner and 5 flushes with hot water. This came new out of package, bright and shiny. The XX1 which had the same treatment and still looking as new.
I’ve hot waxed it anyways and will give it the first kms soon.
Any similar experiences on corrosion during initial degrease and prep? Guess we witness the difference between the high-end chains and the cheap entry-level chains, where the surface treatments show their benefits.:
Though I must say the XT M8100 also showed slight similar surface corrosion after last boiling water reset at 400km (the K1 on the picture below). I don't remember this from my previous MTB with 2x X01 chains (metal color), they didn't show any corrosion at 1500km each. This makes me curious how an XTR M9100 would do. Will take one in next round of experiment.
K1=XT 8100, K2&K3=XX1, K4=Deore M6100
This picture from 1500km X01, no surface corrosion:
irie
3,241
3,380
And the conclusion is?
10,010
I'm sure that I remember correctly, but not when I read it, but....
Sram designed the 12-speed ring to be a bit shark-toothed from new. They were chasing chain retention (and maybe also longevity), and they took a new approach to tooth profile. After all, initially it was a 1x system (is there even a 2x 12-speed set up?)
10,010
I’ll see if i can find any old pics of e bike, but it’s true that it’s been shark toothed for a looong time
I have just been looking at pictures of my 12-speed chain rings and I can't find any shark toothed ones at all. Maybe I was remembering incorrectly and it was 11-tooth that Sram were on about. It could be that it was a development that didn't stand the test of time? Or my memory is making stuff up! :eek:
10,010
This is shark toothing!
New one at the back.
You can also see the burring of the teeth casued by pressure from the chain deforming the teeth.
The 11 and 12-speed rings I have pics of look nothing like either of those!
Mr President
306
213
monmouth,wales
10,010
Now those look exactly like the ones I was describing when I said "Sram designed the 12-speed ring to be a bit shark-toothed from new".
I have just checked on both my last two 12-speed bikes and they were both Shimano! That would explain the difference! Doh! :giggle:
Arminius
735
1,239
Rhein-Ruhr Delta, Germany
I replaced the quickly wearing NX chain by a XO1 and find this tooic interesting. Being curious I found on SRAM website details for the link surface treatment.
Is it known if the base material of the links is the same steel or if there are different grades with different elongation properties used?
Shimano uses for inner / outer link besides chrome plated descriptions like brown and grey, what does not mean anything to me with regard to steel or steel surface.
This is what SRAM indicates:
NX
INNER LINK FINISHPolished
OUTER LINK FINISHPolished
WEIGHT (G)252
WEIGHT BASED ON114 links
GX chain
INNER LINK FINISHBlack Oxide
OUTER LINK FINISHNickel
WEIGHT (G)244
XO1
INNER LINK FINISHChrome Plated
WEIGHT (G)239 (Hollow Pins)
XX1
INNER LINK FINISHChrome plated +PVD
OUTER LINK FINISHChrome plated + PVD
Arminius
735
1,239
Yepp, it is the SRAM X-Sync 2 Eagle 34T for Bosch Gen 4 of my bike, engine side up.
During service and taking chainring off the centering ring (small silver conus) got loose (there is some soft adhesive only) from the chainring and I had checked with SRAM if this is a problem. It is not as the ring is just for leveling out chainring on motor axle and to make sure the conic side goes towards engine side.
10,010
NX
WEIGHT (G)252
GX chain
WEIGHT (G)244
XO1
XX1
10,010
I have no idea, I stopped looking at the detail years ago, I just buy XT chains if it's Shimano (or X01 if it's Sram, but not since 2018). They last well and I can leave washing and lubing until a couple of days afterwards without any rust forming.
irie
3,241
3,380
I believe that's because they have SIL-TEC coating (we use XTR chains, buy them when they're on offer.) [/B]
irie
3,241
3,380
577K
