Scott Lumen eRide 910 customized
Tomoooo
20
15
Slovakia
upgrades (latest update as is)
DT Swiss XMC1501 carbon wheels
Vittoria Agarro 29x2.35 tires
Syncros Hixon integrated carbon handlebars
Shimano Saint Brakes
sram TQ 34t chainring
Sram XX carbon cranks
Sram GX AXS Transmission deraileur
Sram XX cassette and chain
Sram AXS Reverb dropper
SQ lab 60x infinergy seat
DT swiss fork remote
Ergon GE grips
Shimano XTR pedals
Bolts on callipers, fork, brakes replaced by titanium Better Bolts.
Thru axles front and back Carbon Ti
Sly07
13
France
upgrades:
Wolftooth 32t chainring
DT swiss dropper and fork remote
Ergon GE grips
Shimano XTR pedals
View attachment 131786 View attachment 131788 View attachment 131789 View attachment 131790
Nice,
Weight with pédals ?
Marcelfacd
76
42
Leersum
While upgrading, did you remove the motor and battery? I want to replace the brakes but guess I have to remove motor and battery. The hose is very tight and won't move along the battery.
Tomoooo
20
15
Slovakia
I had to remove the motor and also disassemble the rear triangle, there is such a small gap in the main triangle that I was not able to guide hose through it when rear triangle was joined. But that was maybe just me 😁
No need to remove battery. But headset and motor definitely have to be removed
(Ignore the stickers on the table 😂😂, used a table my niece decorated)
Tomoooo
20
15
Slovakia
Also maybe to note, at the time when I was replacing the brake hose, I did not have in the down tube dropper and shifting cables as I am running AXS dropper and shifting, so maybe because of that there was more room.
Also the brake hose is at the bottom of the frame attached to the frame with a zip tie.
Tomoooo
20
15
Slovakia
No need, you pull out the whole motor, you can even leave the cranks there. There is no need to even disconnect the motor. You just put it aside and be careful not to drop it.
Marcelfacd
76
42
Leersum
I did my upgrades and modifications now as well but wondering....what torque is needed for the motor bolts? Can't find them anywhere, my guess would be about 15 or 20Nm but maybe you know?
rocketboy
ct140dn
upgrades:
Ergon GE grips
Shimano XTR pedals
That is sweet. I also have a scott lumen 910 that Im in the process of upgrading. Do those XX cranks fit straight onto the TQ motor?
Tomoooo
20
15
Slovakia
rocketboy
ct140dn
Yeah, those are ISIS version
And to remove old cranks tool like this
For the XX cranks it is enough to have 8mm allen key
Brilliant. Thanks very much. You running 150mm forks as well. What model are they?
simonsmidt
16
Overijse
I need to replace the FSA 34T chainring and want to upgrade to Shimano, the Deore XT M8100 SM-CRM85. Is that easy to do, will it fit?
Above the chainguide is an indicator with 32, 34 and 36 on it. Somehow it moved to 32. How do I get it back to 34?
Tomoooo
20
15
Slovakia
1. regarding the chainguide -> just loose a little bit the screw on the chainguide you see in the front, set to 34 and tighten it back
2. regarding the Chainring replacement. This will not be possible due to compatibility of TQ motor. TQ motor has a TQ specific chainring mount layout for the spider to be attached to the motor.
What you could do, either go for a full chainring (for example Wolftooth has 32T one, or Garbaruk and Ethirteen have also 34T) -> for that you need to get the cranks down (see some posts above what tool you need for that) and then extra tool to remove chainring itself.
example garbaruk
Maybe I would suggest to go for this option instead:
or any 104 BCD 12s shimano chainring should also do ok.
Tomoooo
20
15
Slovakia
Fork is originally Fox 34 Factory 140mm, but I got it lowered to 130mm as was on original , and got remote to it, as the 140mm 34 comes with out remote.
576K
