Rear derailuer is broke...help please
MOTO13
347
390
Elkhorn, Wi
My Niner derailuer (SRAM) started acting up yesterday. Skipping gears then all of a sudden the chain went slack. The chain hangs down and there is no spring tension on the derailuer itself. The derailuer just kind of hangs there flpping around. I was able to barely pedal back to the truck luckily, but the chain is WAY loose. Is this is easy fix by replacing a spring or something. Never had this happen before.
MOTO13
347
390
Elkhorn, Wi
Yup...I think you guys are 100% correct. It looked like it came loose. I figured something broke, but it may just have come loose by the screw backing out. Gonna try to fix it tonight. Thanks for the replies.
irie
3,227
3,361
Chichester, W.Sussex, UK
If a screw has come loose consider a little blue thread locker/loctite, and if there is a torque setting then stick to it.
575K
