What brakes rotor are you running?
1oldfart
684
321
Outdoors
I’ve had my Giant Reign E+ for a few weeks now, and although I like the XT brakes I feel like they could do with more engagement, I’ve been looking at either Magura MDR-P or Shimano Ice Tech rotors.
Question is will going from 203 to 220 make a difference and also what rotors do you guys & gals run?
My fist step would be to go on asphalt and really heat them, new brakes usually underperform.
Check youtube. If need be Magura is high on my list.
johnf0246
139
71
Sedona, Arizona
I’ve just bent the rear rotor on my Merida e160 and replaced it with a Swissstop rotor. It’s great but the problem was what to do about the magnet. For now I’ve just epoxyed a magnet to the rotor but planning a more robust solution with a thin sheet of titanium.
I use JB Weld and fiberglass cloth to fasten a magnet to a regular rotor. I have done this about four times on different rotors. I works great.
ebkilla
47
9
California
Code RSC On my Decoy Sram 220F/200R, I could use more power. Instantly noticed the 220 on the front it should be mandatory. Thinking of upgrading to Formula Cura 4's with a thicker disc and 220F/220R. I have always had the best experience with Formula brakes.
pedrod355
44
Currently running stock sram G2 r brakes 200m rotors ,but hate the bite point been to close in and not best at stoping.Could someone help with advice to fix this? Was thinking replace with galfer discs & purple pads? Would this make a difference ?
irie
3,237
3,376
Chichester, W.Sussex, UK
Trek Rail with Swissstop Catalyst Pro 220mm rotors front and rear. Coupled with Shimano M6100/M6120 levers and calipers they are super quiet single finger stoppers with loads of feel. Have Shimano organic pads (D03S) but will soon try Swissstop Disc 27 RS pads.
D
Deleted member 28340
Guest
V4 floating 220mm front and back.
Not had any issues with heat and perform really well in wet muddy conditions.
iXi
501
401
Brisbane
I bought magura
MDR-P​
220mm
And it made a world of difference
Hiltix
47
89
Swissalps
Somehow not very well known, but I am very satisfied with my Braking S3 BATFLY (Non-Round / Semi-Floating) with Magura MT7pro. 220 in front and 200 rear.
576K
