bosch performance cX 4 th generation. ERROR 503
Silpa
Italy
Hi everyone, I am the owner of a Lombardo dc90 ebike
fitted with a 4th generation bosch performance cx. For some time (about 1 month) I mounted a modification to exceed 25 km / h. The modification is called eplus (Chip Bosch - Ebike Tuning).
One day the bike no longer gave assistance and I solved it by returning to its original state and removing the chip. The bike ran smoothly for about 2 months after disassembling the chip.
After about 2 months from the disassembly of the chip, I get the error message 503.
I took the bike to a bosch center and they replaced the battery first, then the charger. I thought I had solved it but again I get error 503.
I mount the slim speed sensor and the appropriate magnet.
I have had the electronic diagnosis done several times and the chip I had installed never resulted from the diagnosis. I have now ordered a new sensor and magnet and they must arrive.
Do you think it can solve or do you think it depends on the assembly of that chip that I removed? Thanks everyone for the answers.
Rusty
E*POWAH BOSS
Jul 17, 2019
1,513
1,673
New Zealand
Stolen from somewhere when I got a 503 - mine was lined up with the bolt and not the sensor. Apparently this is pretty common.
RustyMTB
3,050
7,390
A 503 error is a speed sensor error, usually around the magnet becoming misaligned with the sensor. Bosch recommend the magnet should be spaced between 8-14mm from the sensor. Your bike is the same as a Decathlon Stilus, so the magnet is mounted on the spokes. I would look there first.
I have also seen on here a guy who had ££££ of warranty work done chasing the same error only to discover the speed sensor wire wasn't fully pushed in to its connector at the motor.
Silpa
Italy
Today I try to check the wire harness to the engine. For the sensor I mount a different one and the magnet is screwed onto the disc with 2 screws. It cannot move.
All4Fun
106
46
the Netherlands
The line and distance are important, had some 503 errors here, distance was to big, lined it up with a 5mm gap, but after some months 503 again, changed the gap to 11mm and no more 503's.
575K
