I am going to do some testing in the coming weeks on the two motors.
I have a sneaky suspicion that they are now identical motors.
1.2E is in the 2019 Kenevo Comp. 1.3 is in the 2018 Levo and 2018 Kenevo Expert and 2019 Kenevo Expert.The 1.2E motor is only built in the 2019 "budget" Kenevo Comp and all other versions (Levo & Kenevo) stay with the 1.3? Or is this a secret yet?
I have a feeling that the 1.2E is a marketing thing.okay, thanks Rob. I guess there will be a 2019 Levo as well - just curious if it's just color changes or changed specs, too. Would not make sense to change the 1.3 motor to a 1.2E on whatever Levo version cause there are already "budget" Levo models available. Or they go to the 1.2E on the cheaper Levos and upgrade some other components... so many questions, so hard to wait![]()
Not so sure anymore. In the past yes definitely, but from sources I'm hearing that there are few, if any, internal changes between the motors now.lots of different internal components, internal heat sinks revised wire plug system more external heat sinks. they had to improve the heatsink thing for the carbon frames and allow higher sustained power
That what I want to test.without the new magnets/internals (so no 15% power increase) to keep costs down.
Yea, the old motor was the 1.2T and my guess would be that the 1.2E is a revised version of that motor, with a head pad etc to counter the overheating issues, but without the new magnets/internals (so no 15% power increase) to keep costs down.
Interesting! @PaoloBLEvoIt has the same hardware as 1.2 motor but it is tuned to consume less energy than 1.2 motor.
hmm not sure if this makes the choice harder or easier £3750 for a comp and £400 on a range extender or get a 2018 expert for 4600.. agree that motor doesn't make sense in the heaver bike
Hi all! I am about to buy the 2019 kenevo comp (first eMTB). But after doing a little investigation I have doubts regarding to the motor. Why would they put a weaker and older motor than the 2018 turbo levo fsr (it has the 1.3) In a 2019 model? Is the 1.2e brose drive T o Drive S? Anyone tested and compared the 1.3 with the 1.2e?
Thank everyone!!!!
'E' on 1.2e motor stands for 'Economical' - motor is tuned to consume less energy.
It is the same hardware as 1.2 motor but with less peak torque.
1.2 has 75 Nm at 60 rpm cadence while 1.2e has 50 Nm.
1.2e motor offers around 30% more ride time compared to 1.2 motor, with identical battery (also around 30% less power)
For straight power comparisons, you could run Mission control in "battery" and see what the bikes are pulling. The 1.3 normally pulls 20A. How this actually converts to useable torque though .. who knows.We have not tested this scientifically yet, just all different motors in exactly the same bike over several years gives you a pretty good feeling.
Anyway, hope this helps.
Great work Kiwi. Interesting your statement regards noise too. We have noticed that the new Brose drive belt is too wide for the pulley guides and puts a lot of stress on the edge guides of the large drive pulley and belt tensioners pulley guide. These guides seem to be wearing and future longevity will be interesting, although it seems to just wear the edge of the belt away. This I think is where most of the noise is coming from in the later motors.Hi all,
Not sure if any of you guys use Blevo but it supplies you with all the info (and much, much more) that you have been talking about In the above posts. Motor temp, Battery temp, Motor Power measured in Watts, and loads of other geeky measurements for the entire ride which you can view after your ride on your phone. If you want even more detail like Current draw measured in Amps, you can download the CSV output file that has an output measurement for every second of the ride that you can easily download and ‘geek’ over. I don’t know how accurate the info from Blevo is but I guess it will be within + or - 10% or better?
From the data I have the gathered from the 1.2 engine in my newly acquired secondhand 2019 Levo HT on ‘Turbo‘ mode I consistently get outputs of between 580 to 601 Watts of peak power with a Current draw of 15.2 to 15.4 Amps. Motor temp will go over 50 degrees centigrade if consistently climbing on ‘Turbo’ but so far I have never seen it go over 55 degrees. Also, I have noticed it is very economical even on ‘Turbo’ with a 400 Wh battery and if you flip it to ‘Trail’ mode or ‘ Eco‘ it is of course even better. The thing that I ‘really’ noticed is how quiet the motor is compared to any of the 2.1 and 2.2 engines.
My Comp Carbon 2019 Levo FS with the allegedly ‘improved’ replacement 2.2 engine on ‘Turbo’ mode consistently outputs between 710 to 723 Watts of peak power with a Current draw of 19.0 to 19.2 Amps. Now the next bit is interesting as it could be due to the carbon frame not being the best at heat dissipation. Heat definitely increases on these engines. On ‘Trail’ mode if you are continuously climbing it will creep up to nearly 60 degrees. On ‘Turbo‘ mode I have seen it exceed 70 degrees which is why I have asked @PaoloBLEvo if he could add motor temperature to the voice alerts on Blevo so I can back off if it starts to hit a scary motor temp as I carry my phone in my body armour so I can’t see the display.
The question I have for @Specialized Rider Care is what is an acceptable motor temp and what temp range should we be trying to keep within? Is this possibly a reason why some motors have been failing and are still failing? I do not know what damage a consistent 70+ degrees will do to an engine or belt so your feedback or anyone else that knows about heat limitations on an electric engines in ebikes would be much appreciated.
Maybe the heat output is not so high on the engines in the aluminium frames with the 2.1 or 2.2 engines in them but I do not have one to give you the feedback on. It would be good if someone who has Blevo and an Ali framed 2019, 2020 or 2021 could do some testing and feedback their numbers to compare?
I have a 1.3 engine which I purchased from Berks cycles a couple of years ago as a spare which I am going to drop into the HT to see what the temps are like continuously climbing on Turbo mode. I can only presume it is going to rinse the 400 Watt battery in just over half an hour as I know I measured the 1.3 engine output when I first got it and it was putting out figures of 740 to 750 Watts and a Current draw of 20 to 20.1 Amps.
Anyway, hope the above info helps and I will feedback what I capture on the 1.3
