Levo Gen 3 Chainring 38T
ruppia
250
183
Italy
Hi all, yesterday I mounted the new chainring from ethirteen, direct mount.
I was worried if the 38T would be fit, but as you can see it mounts perfectly. Already with 36 teeth I had to remove the chain guide.
In Italy it's raining a lot so I'll test it only during the weekend, but at the dyno the gearbox looks perfect with 2 more chain blocks.
Luca
Rosemount
822
1,748
Qld Australia
Careful when riding over trail features .
The chain ring is now the lowest point . It will hit logs and rocks if you try to climb them .
I have 36 T and I cringe when it scrapes over things .
ruppia
250
183
Italy
Thanks, i will check in the afternoon and post some new photo
greengenes
46
24
uk
Make sure you keep the chain well lubricated, and not worn: if you get chain suck, it will get stuck against your frame. Messy.
akira
164
73
SanDiego
Luca
How close does the eThirteen 38t chainring come to the frame at the chainstay when the suspension is fully extended? I tried a SRAM 38t on my Levo Expert and it lightly touched frame when suspension was at full travel.
ruppia
250
183
Italy
Hi how is it working? This chainring which fits to Levo 2022 gen3 is for Direct Mount Chainring for Brose S Mag. Am I right?
Yes, you are right. you can find it with direct mount or with a spider and 4 screws
maramouse
185
126
Genoa Italy
Hi everyone, I chose a different way, instead of mounting a 38t chainring and having to replace the cassette, I mounted an E * 13 9/50 cassette, obtaining what I wanted with the 9 tooth ratio.
ruppia
250
183
Italy
And what is your feedback ? You rode many km ??
576K
