Can you use SRAM brake hose with Hope brakes?
Cb750stu
504
475
United Kingdom
I don't see why not you would obviously have to change the fittings , barb olive etc to fit the hope brakes ?
I would imagine the brake line is the same size
RickBullotta
1,868
1,594
Should be fine - both 5mm DOT 4/5.1 fluid. The real question is how much hose you'll need to chop off to remove the old fittings and whether it'll be too short afterwards.
Dave_B
1,470
1,603
Newquay
Cheers. The cable is also quite long at the lever end, so plenty to play with. ?
RustyMTB
3,012
7,284
Yes you can. The hose diameter is the same, more importantly, I've done exactly that with one of my bikes, V4's replacing Guides & kept the hoses for this exact reason.
571K
