Reliability of t type setup
Begazzz
27
14
Uk
Hi all.,
Quick question on the setup and the reliability. I’ve a new crafty carbon rr and it has the t type axs. Went for my second 20 mile loop and gears started playing up. Obvs a bit confused as I didn’t really know how to sort it. Anyway called it a day and on inspection at home both rear wheel and derailleur bolt were a bit loose. I’ve just reset as per sram video and now fine. My only concern is how reliable is this positioning in action? As there is no mechanical fix other than the torque and the knurling cutting into the frame. Anyone had issues? Or do I now need an 8mm hex in my emergency tool kit? (Arguably I should anyway after my crank fell off the last eeeb)
Thanks.
Dax
1,506
1,871
FoD
Invest in a torque wrench and some thread lock.
Begazzz
27
14
Uk
I’ve got torque wrench and thread lock thanks. Wheel bolt was torqued to the correct setting. I can’t speak for the derailleur as it was shop set. Is thread lock widely used in the particular application?
Dax
1,506
1,871
FoD
I use thread lock for everything on bikes apart from wheel, seatpost and lever bolts. I wouldn’t assume the bike shop had bothered to torque it up, I always go over new bikes with a torque wrench because I’ve had a lot of stuff come loose.
6,180
4,700
rear thru axle should be greased and a lever type avoids the need for a tool, so if it is just the allen key type maybe invest in a lever type. Rear mech is bolted on dry...no grease...and torqued correctly.
526K
