Neat rear brake hose
mariop7
italy
Hello,
help wanted for a rear brake hose replacement, any procedures? tutorials? suggestions?
p3eps
1,900
2,276
Use the SRAM barb to PUSH through the frame - don't pull it.
The way I did this using a non branded ‘SRAM barb’ was…
Disconnect the hose at the caliper, and chop the connector off. You now have a bare hose end.
Screw the SRAM barb into it.
Screw the new hose (lever end) into the other side of the SRAM barb (remove any existing ferrules etc if necessary).
PULL the old hose from the lever end through the internal frame routing carefully and slowly. As it pulls out, it’s pulling the new hose in.
Once the whole new hose is through, remove the SRAM barb and fit a new ferrule / barb to attach it to the lever.
Fill with new fluid and bleed as required.
mariop7
italy
Thanks a lot for the suggestions, I am warried about the zip tie around the cables in the attached pictures, anyway I will update when completed, thanks again
cheers!
527K
