G-Sport
266
206
Yorkshire
Yeah. I looked after my last ride, and the rubber ring was almost at the bottom. And that was after the guy at my Specialized shop filled with air. I stopped by the shop on my way to go riding in the trails near my house. Max air pressure in rear shock is 300 psi, isn't it? I think he put max air pressure in it. Here is a picture of where the rubber ring is on my shock. I drew a red line where it is. So that would be around 80% - 90% sag, right?
Whew. NO. That isn't sag, that's your max travel for the ride. Go watch some basic YouTube videos on suspension set up.
Apr 11, 2023
101
20
Japan
Yes, you're right. I have watched a number of videos on setting sag. Also, the mechanic at the Specialized shop set the sag for me when I was sitting and standing on the bike. But I misunderstood, I thought once the sag was set that the rubber ring should not go so low. I just put air in it a few minutes ago and it's now at 260 psi. I can't get anymore air in it than that with my shock pump because the limit is 200 psi.
bakedbun
7
8
California
I believe the Float X shock is 350 psi max but please check the manual to make sure. If you're not feeling a harsh bottom out (pain in the ankles) then I wouldn't worry about it.
Apr 11, 2023
101
20
Japan
Yeah, I think it is 350 psi after searching for it today. We'll see how it goes. Maybe 260 psi will be enough for now. Sorry for the confusion.
bcmtb
27
18
WA
Took delivery of a levo SL alloy today S4, stripped down to the frame and rebuilt with parts I already had. Knocked 1kg off the standard build weight.
I'm booked for a weekend of uplifts, dirt farm and bike park Wales. I was going to take the non e, but I'm considering taking this instead now!
The colour looks awesome! Wish we got this in the US.
bakedbun
7
8
California
Wanted to slack the HTA a bit. Is there supposed to be a small gap between the headtube and cup?
GolfChick
41
16
How was it to strip down as I'm considering doing similar and buying a low spec model.
twitchyzero
11
12
PNW
does anyone know how much S2 alloy weigh? S4 carbon v S4 aluminum is 4lbs difference for $1k difference
the Alloy model is practically neck-to-neck with carbon only Heckler SL for weight and price (base trim obviously)
thank you
beutelfuchs
177
100
Barcelona
Who tried a mode which adjusts the motor assistance accordingly to your heartrate? How are your impressions? Is it cool/useful?
Heart rate I found pretty useless when terrain inclination changes a lot, as HR is lacking behind.
With Levociraptor you can also autoregulate support by rider power which is much more useful.
Ou812
643
443
Fort William
Just installed my Cascade link and a Storia tuned to the new leverage. Looking forward to a ride tomorrow.
This is exactly what I’m looking at doing if Spesh ever gets their fingers out of their butt and releases some of the frames they have sitting in the warehouse.
How does it ride with the link? I have the shock already, just need the link and a frame to put it on.
526K
