Energypak 625 not working or charging
playerako
Hungary
Hi, I have a Giant Energypak 625 that is not charging, and the bike doesn't turn on with it. When I press the button, only one led lights up, and it's blinking (the first led next to the button).
I checked the voltages:
pin 1: -
pin 2: 2,5v
pin 3: 2,35v
pin 4: 2,7v
pin 5: 32,7v
pin 6: 0v
What could be the problem? (Charger and bike works perfectly with an other battery.)
Rubinstein
408
535
kent
Sadly not much you can do here. If it’s out of warranty then it’s a new battery required.
paullin523
8
Indianapolis
There's a company in one of the Nordic countries that can repair your battery.
Each group of internal batteries are connected in series, then in parrallel. Each unit
should have similar voltage readings. The BMC controls this.
If one cell fails, the whole unit becomes unbalanced and will not function. Look into
repair rather than replace.
529K
