The new bosch purion 200
Dano78
162
34
Uk
Has anyone ordered the new bosch purion 200 controller yet ? I think it looks good can get rid of the big screen now just wondering what people's thoughts are
Jackware
Fat-tyred Freakazoid
1,924
2,083
Lancashire
I'm planning to order it once it's available, hopefully from next week, but it has to be coded to the bike by a Bosch dealer.
TommyC
257
192
Hampshire
Just had mine fitted today. It’s a little chunkier than the led controller and doesn’t have any adjustability for mounting. Seems to do everything the led controller/kiox combo does other than navigation.
The motor ID has to be transferred to the purion. At this point the controllers can be swapped out and the bike will work. But only one controller can be registered to the flow app at one time. You have to reset and remove the bike from the app and reconnect with new controller. Kiox 300 can be linked in and out whenever you want.
megabobra
226
252
Mine just turned up yesterday as well. I haven't fitted it yet but I'm disappointed about the lack of adjustability in the mount. I use solely my middle finger for braking (a habit I've never been able to lose) so my brake mount is located quite close to the grip, ~10mm. Sadly the Purion200 won't fit in this gap, meaning I either have to move the brake mount further inward (and make some new indentations on my carbon bars) or mount the Purion inboard of the brake mount, probably making it too far from the grip to reach comforatably.
Seems like a pretty a pretty pointless physical change to lose the lateral adjustment that the LED controller already had...
6,208
4,712
No need for a dealer fit...its plug and play other than the fact you have to re- pair with the flow app which is simple enough. Delete the previous pairing on your phone then run flow, use you existing Bosch account on flow then go through the pairing process as per the original LED Remote.
megabobra
226
252
That's outstanding news, as I was dreading a trip to the dealer. I did try pairing already actually - phone successfully paired with the new module but Flow wouldn't recognise it. I didn't try deleting the pair of the old LED remote though, I'll give that a go.
6,208
4,712
I changed a LED Remote once. I think what I did was delete the flow app and then reload it. Delete the blutooth pairing on the phone. Then run the Flow app using you existing Bosch account details and do the pairing process. Not sure if all of that is necessary but it worked!
megabobra
226
252
Yep, confirming that worked a treat - thanks very much. All paired up and working now. I'm guessing the requirement from Bosch that states you have to take it to a dealer is simply 1) so they avoid having to troubleshoot people's smartphones/apps, and 2) to get customers in the store to maybe purchase the latest and greatest gear.
jalex
Spain
Are you using it alone or together with the Kiox 300? Thx!
Philippe M
9
California
Question on the Purion 200.. can the mount be narrowed to fit in the xt brake gap? Either by filing or milling the width so it will fit in the brake gap.
TommyC
257
192
Hampshire
If you mean the gap between the clamp and the little brace, it does fit as shown in my picture above. Pretty sure it’s designed to sit right next to the clamp with the little dip it has in the back of it. You cant really sit it anywhere else. It is a faff to get it on though. You have to fit the brake and controller simultaneously. I’ve also got a matchmaker for dropper lever which makes things easier.
529K
