Does anyone have a matt moss coloured one that they can take some outdoor pictures of? I'm considering the E-150 29er RS, just not sure about the colour...
It’s on eBay @steve_sordy@highpeakrider What did you do with your Focus?
@highpeakrider seeing as you've now had time on your new bike, how does the Bosch motor compare with the Shimano regarding noise, I don't mean the much discussed rattle but the actual motor noise, is it any worse than the Shimano when doing about 15mph on a flat track for example?
This is the only one I’ve taken and I probably didn’t consider the background too well... it blends in a bit. I like the colour, looks great in the flesh (last bike was bright orange though so maybe I’m just enjoying being slightly less conspicuous).
The Bosch does not whine, its a different noise which to be fair I've not really noticed the motor noise when riding, I've also not noticed any knocking on rough terrain.
Power wise it seems a lot stronger and faster to respond, I was on a step hill the over day and had to move to a flatter section to get started, in EMBT the bike just wanted to wheelie no matter how little power I tried to feed in.
Overall I'm very pleased with it, just have to adapt to using EMBT on the technical elements or where you want control over power delivery and learn how to apply it, you soon start to get used to it.
Phil,
I had a quick go on the 160RS today, have ridden the 150 last year - Definitely the best EMTB on the market IMO right now for UK riding if you want the a big battery (caveating that as it still weighs a fair amount), totally sorted out he box with a great spec in terms of the things that matter, and so much fun to ride, and great looking to boot. Its handling is what sets it apart.
I'm running 2.6 eddy currents which have enough clearance. I tried the 2.8 version which did fit but it was a bit too tight for my liking.Reminds me of my old T130, point it downhill and go, gives great confidence and I seem to be going to fast for my years. The rear triangle seems a little small with not a great deal of clearance with just a 2.5 on, I’d like a bit more mud clearance.
Would you mind to share which bolts you bought? Size length and material? I just ruined the torx head of oneHave swopped the tort bolts for standard Allen key ones for that purpose. thanks for the advice
took the original to local diy store and replaced with hex sorry can't remember the size have been fine though also attached a cord to the battery makes it a lot easier to swop out.Would you mind to share which bolts you bought? Size length and material? I just ruined the torx head of one![]()
Picture please!Also attached a cord to the battery makes it a lot easier to swop out.
There are two brass threaded inserts either side of where the wiring connects on the battery. 4mm thread. I screw a long bolt into one of those to use as a pull handle to lift the battery out.Picture please!![]()
