What tools do you own and have used?
Which of these tools do you own?
  • Screwdrivers
    Votes: 72 92.3%
  • Allen keys
    Votes: 78 100.0%
  • Torx bits or drivers
    Votes: 74 94.9%
  • Cassette socket
    Votes: 67 85.9%
  • Cassette wrench
    Votes: 62 79.5%
  • Chain wear tool
    Votes: 65 83.3%
  • Torque wrench
    Votes: 71 91.0%
  • Socket set
    Votes: 71 91.0%
  • Tyre pressure gauge
    Votes: 73 93.6%
  • Shock pump
    Votes: 71 91.0%
  • Looked online to find manufacturers maintenance guides
    Votes: 60 76.9%
  • Total voters
    78
Landy Andy
192
191
Herts
The problem I have is that I, in the majority of cases, know how a job should be done. Every now then I choose to get someone else to do something for me, and I’m always disappointed at the results.
6,856
5,306
I have always maintained my own vehicles having built race cars from a bare shell in the past and built race engines including doing the machining of block crank rods pistons etc. Once I gave up racing and then had a succession of company cars over many years I got out of the habit of DIY car maintenance. But as far as bikes are concerned I would not dream of letting anyone else do work on my bike except of course for things I am not allowed to strip like the motor, or where specialist tools required for a one off job are not worth the investment.
The forum seems to be split between those that rely totally on their LBS........even for servicing ( who knew that was even a thing!), whilst others prefer to do their own maintenance even if they have little or no knowledge; those with no knowledge using this forum very effectively to get advice.
10,040
I have always maintained my own vehicles having built race cars from a bare shell in the past and built race engines including doing the machining of block crank rods pistons etc. Once I gave up racing and then had a succession of company cars over many years I got out of the habit of DIY car maintenance. ......................
When I started car maintenance, there was so much room under the bonnet that I could almost get in there and stand by the side of the engine! Now the area under the bonnet (hood for the Yanks) is completely full, I can't even see the floor under the car FFS!
Andy.M
176
105
Rochester UK
Yep, for certain jobs on the car I would sit on the wing with my legs dangling in the engine bay. Cant even get your hand in there now days let alone find a spark plug!
RustyMTB
3,074
7,474
I remember changing the air/oil separator on my Cayman which involved undoing two bolts via the inspection panel behind the drivers seat & fully three feet of ratchet extensions.
Say what you like about MTB's, the parts are generally very accessible.
smtkelly
204
184
ldn
Always liked making things, fixing stuff comes naturally. With Youtube its infinity easier to learn new skills (all of my wood working skills came from Youtube).
I found it far cheaper with better results to buy the tools and do jobs myself than most of the cowboys. I have a few exceptions if the price of a single fur cup is more than paying a trade to do the job, if its seriously danger such as my roof ridge tiles that need reseating or just too big a job for 1 person.
For bikes I'm happy to tackle anything short of wheel building the investment in time to learn the skill and tools isn't worth it.
Andy__C
107
112
South Wales
Friday nights in the garage, a few beers, tunes on, bike in bits. It's a good time (y):D
(Well... especially the last year when there's nothing else on Friday nights).
I'd probably add circlip pliers and a strap wrench to your list if you like to get your suspension/seatpost in on the action.
BushLevo
82
33
Melbourne, Australia
2 weeks ago I liked to change my rear tyre on my MV Agusta Stradale.
The wheel nut sometimes get stuck, and it has to be set at 240Nm....and my own 2 meter long shaft was not enough.
So I went to the local tractor-tyre-shop to get it loosened.
He laughed at me.....that nut would soon be loose - he's used to work on tractors with great force.
But actually he broke his tool (1" with a massive air gun) and said: "that nut is stuck for good !"
So I had to get this bastard.....it loosened it like it was softice !
Similar deal with the rear wheel of my 2015 Ducati Diavel. The central locknut is set to 230Nm, but it can require 500-1000Nm to crack it loose. I do this with a 55mm 3/4" drive socket and a 1 metre long breaker bar. Leave the bike on it's sidestand, place a 12kg weight on the rear break pedal, and then put about 1/2 my weight on the breaker bar. Works every time.
routrax
382
530
Uxbridge
I predict a large percentage of those who hasn't used a chain wear tool will post a thread asking why their gears are slipping in the smallest cogs at some stage.
578K
