What should my next upgrade be?
What should be next upgrade be?
  • 220mm Front Rotor
  • Charger 2.1 Damper (running the stock yari damper ATM)
  • Vorsprung smashpot
  • Other (post a comment)
Results are only viewable after voting.
Aug 6, 2021
10
Sydney, Australia
Howdy all,
For reference I ride a 2018 Merida e160 800 with the following upgrades:
1. 29er Front
2. DT Swiss FR560 (Rear)
3. Hope Tech 3 V4 (front) and X2 (rear) - 203mm front and rear
4. A1+ C1 spring upgrade (180mm - up from 160)
I also tend to ride reasonably rocky terrain with frequent drops/ jumps to flat.
Aug 6, 2021
10
Sydney, Australia
Might be worth clarifying which other modifications/changes you’ve already made to your bike then for others.
May have forgotten I actually had my insert installed. 🙃
But to better answer your question the full list of upgrades (doesn't include crash replacementa):
1. 29er Front
5. ODI SDG Grips
6. Rimpact Pro (rear)
7. 1 XT crank arm - 165mm (only replacement I could get my hands on and no I'm not running different length cranks)
8. XTR FH-M9010-B rear hub (more of a replacement)
And that's it I think.
RustyIron
1,725
2,658
La Habra, California
With your current setup, what are the limiting factors preventing you from riding faster, smoother, and having more fun?
The Smashpot might be a nice upgrade. Better brakes might be good. New/better tires can also make a world of difference.
Doomanic
🛠️Wrecker🛠️
8,636
10,224
The MoCo damper in the Yari is shite, get the Charger 2.1.
Gary
Old Tartan Bollocks
10,496
10,699
the internet
Those "shite" Yari dampers seem to work absolutely fine for a lot of folk who actually ride fast
Doomanic
🛠️Wrecker🛠️
8,636
10,224
And I bet they’d be faster with a Charger damper. What’s your point?
Litehiker
73
31
Las Vegas, NV
I'll get my new E-MBT (E-CELLS Super MonarchCrown) in January. It is HEAVY at 95 pounds but it has 2 motors and 2 batteries and Dual suspension. I have L4 and L5 disc problems so of thereat suspension os to stiff at softest setting I'll need a shock absorbing seat post as well.
544K
