The plastic guides fit in your calipers if you take the wheels off to transport the bike.
They avoid the pads being moved too close together accidentally.
The clear pads are for protecting paint on the frame from cable rubs.
That’s brilliant, thanks guys. Yeah I’m guessing maybe for the water bottle mount but I would never have guessed about the calliper guards. Many thanks
You can also get these brake spacers (which I recommend if you're planning on bleeding your brakes at any time):
These are wider than the orange ones are are used to hold the cylinders apart when you have the brake pads out for any length of time and especially when bleeding the brakes / replacing the brake oil. They protect you from your own idiocy (which I find necessary!) Squeezing the brake handle is far too easy to do and is a bad idea without anything to stop the cylinders coming together
