Hey dudes, I have a reaction hybrid exc 750 and I experience this weird resonating metallic sound whenever I'm pedaling between 25ish to 28ish km/h. It's not constant, and it's not always noticable. I can reproduce it every time I pedal hard to the mentioned speed, I can then even feel slight vibrations through the pedals.
I did some testing to see what could it be, but so far no luck. On work stand there's no sound. Motor shut off, the sound appears, doesn't matter which gear. Obviously tightened all the bolts and just checked spoke tension with my fingers. Regularly after every cleaning I have to center the calipers because they rub on the pads. The rotors are not wobbly. I already accepted that the rotors rub on the pads when I corner, so what could it be??
On unrelated note, my arse hurts like seven hells after 2 hour ride, should I change the seat or get padded shorts first (did 900 km in past 3 months).
