WARNING! To Bosch powered ebike owners (pre 2020)
Daev
249
289
Cornwall
Just check our Facebook page and scroll down to the Trek post. Not sure if the cover we speak about is fitted to your model but if it's you may want to read this post or you will be changing bearings every week! (y)
Oh dear - thanks for that. Unfortunately I don't do social media anymore. Started with them from day 1 way back when but gave it all up a couple of years ago. Never got into Twitter or Instagram
Daev
249
289
Cornwall
I'll use my wife's to check it out - cheers 👍
Bearing Man
Ebike Motor Centre
983
2,355
Yes, remove, clean and re-grease the bearing covers every two to three months. At the same time, remove the chain from the front chainring and rotate the pedals backwards and forwards, the motor should feel free and sound quiet. Any noise, play or resistance should be looked into as soon as possible. Catching a motor problem early is the difference between replacing one bearing or one motor. BOSCH GEN 4 SEAL KIT
Daev
249
289
Cornwall
Yeah, got one of them 😱 - what's the solution d'y reckon ? Bigger sprocket ? Any idea where I can get one from and is it just a case of swap it for the original and all should be good or do I then have to leave the chain guide off as well ? Any idea what effect the larger sprocket would have on the gearing / strain on the motor ? Cheers ( sorry for queries but genuinely ignorant 😁👍 )
Bearing Man
Ebike Motor Centre
983
2,355
Remove the cover and put it in the draw. Trust me, it doesn't look bad. The cover also stops you fitting a larger sprocket too! Fit a 17 tooth sprocket if you are using an 11-42 rear cassette or a 17 or 18 tooth if you have an 11-46 cassette.
The larger sprocket will help any mud that builds up to break away before coming too compacted.
It will also encourage you to use a wider range of gears because you will not be spinning out on the lower cogs all the time, this in turn will make your rear cassette last longer!
Do all that and fit a MudStop and seal and you should extend your motors life exponentially for about £45.00 (y)
Daev
249
289
Cornwall
Cheers - so very much appreciated
Daev
249
289
Cornwall
@Bearing Man - looks like I've got one of these cassettes, so guessing 18 tooth should be ok ?
SRAM XG-1230 Eagle, 11-50, 12-speed
The crank is one of these - Race Aeffect, 15T w/chain guard
I'm assuming this 18t should do the trick -
21,686
I didn't know you did a gen4 kit. You need to do a post !!!
I take it it's really heavy if it comes with a lifting tool ? :)
Phil3
18
28
Lake District
Great bit of advise 👍🏼
I’m all new to eMTB’s and have just got a Focus Thron² 6.9 last week with the Gen4 motor… what you’ve described above, is this fairly straight forward to do? or do you have a quick link to any video’s/instructions? cheers
Bearing Man
Ebike Motor Centre
983
2,355
Yes, 18 tooth will be good with an 11-50 cassette. Not familiar with "Race Aeffect, 15T w/chain guard" so can't comment on this.
Bearing Man
Ebike Motor Centre
983
2,355
Good instructions in the pack but you do need a C-clip tool which many do not posses. I will scan and add instructions soon.
Bearing Man
Ebike Motor Centre
983
2,355
Does it matter having the chainguard of miranda?
Is it necessary?
In difference with mud build up?
Stops you ripping your trousers on the sprocket :p No, it makes no difference to your motor if mud packs down the front of the sprocket because it can't get into your motor from there.
RustyMTB
3,074
7,474
Wait! What, Pete? I can do a bearing clean & re-grease with just circlip pliers? This is music to my ears!
RustyMojo
166
105
Gloucestershire
it would be really helpful if there was a home ‘regular service’ guide for the Bosch 4 series motor? Or have I missed something. @Bearing Man thanks for the above. I can see me ordering the seal service kit from you regularly. But a guide would be helpful so I know what I’m letting myself in for.
In terms of annual servicing of the Bosch Gen4, what’s normally required and cost? I think I’m going to drop my motor each year to send to you.
Bearing Man
Ebike Motor Centre
983
2,355
No annual servicing is required. Just the seals from time to time. These motors are not really something you want to keep taking apart and putting back together again. They are the epitome of "if it aint broke don't fix it". But if anything starts to go wrong, feel wrong, sound wrong, STOP! Get it looked at because every pedal turn will cost you more money.
RustyMojo
166
105
Gloucestershire
That’s great thanks… is there a how to guide on the seal change so I can look at what’s involved?
FWIW you have my business moving forward, just on the amount of time you guys invest helping folks on here! Thank you!
RustyMTB
3,074
7,474
There's a PDF link to the process in Pete's reply to me above.
Gyre
634
426
Pasadena, CA
Hi Bearing Man. Thanks for your input. Do you have a video or written guide on how to do this? I skimmed through the Bosch videos you have but it didn't seem like any of them were applicable.
RustyMTB
3,074
7,474
Embarrassing but - fell at the first hurdle. Crank bolt, 8 mm allen, is locked solid. I know it should turn anti-clockwise and I'm guessing twatting it with a big 'ommer is not a good idea.
Any useful suggestions in how to get it done would be very gratefully received
Crank bolts are normally right hand thread on the drive side & left hand on the non drive side to prevent precession. You are turning the right way on the right crank, right?
Daev
249
289
Cornwall
yeah, sorry Rusty - just deleted the post as I sorted it - all it required was a bit of creative leverage with a breaker bar and using a mallet to prevent the crank spinning - worked a treat - onwards and upwards ..... Thanks again.
Daev
249
289
Cornwall
@Bearing Man - well, false starts and hiccups aside, definitely think this needs doing - many thanks. I'm now about to put an Sram 18t sprocket on. However, the 15t seems to have a 3mm offset for some reason whereas the 18t doesn't. Also, if I ditch the cover, how do I secure the sprocket in place ?. I need to clean it all up properly and observe. It's dark here now and can barely see what I'm doing.
The 15t sprocket has no label on it so can't i.d. what to look for.
Check this muck out! - 350 miles, eh?
578K
