Levo Gen 2 Wahoo bolt and Levo
Howz
416
467
Chester
I’ve been running a Garmin edge 1000 with my Levo for a long time in conjunction with the ebike field app and also adjusted the 15.5 mph limit up with Blevo.
I have read some of the issues regarding the wahoo bolt reading the wheel size from the Levo sensor and giving a incorrect mileage readout that does not happen with the Garmi, my wheels are 29“ and mission control is set at 2000 instead of 2300 ish that it should be, my question is does the wahoo bolt still take the info’ from the Levo sensor which I presume is now 2000mm.
the reason i want to change from the Garmin 1000 is that I find it too big…….should I just change it for a Garmin 520 which would be a lot easier if the change to the wahoo is going to be a pain?
551K
