Tyre pressure gauge
  • Thread starter Deleted member 2899
  • Start date
D
Deleted member 2899
Guest
Does anyone know if the Topeak Digital Tyre Pressure Gauge can be used on car tyres?
Alan
Gary
Old Tartan Bollocks
10,496
10,702
the internet
If the head fits. Yes.
Car tyres are generally inflated to lower pressures than pushbike tyres.
*ignoring stupid fat and plus tyres.
Matt Seabrook
62
47
St Austell Cornwall
I brought the Topeak gauge and it’s no wear near accurate. It’s about 20% out so don’t use it. My track pump is fare better but you can only get to within a couple of psi as the gauge resolution isn’t great.
Doomanic
🛠️Wrecker🛠️
8,702
10,342
My Topeak gauge reads the same as the gauge on my Michelin 12v tyre pump and my shock pump (in so far as you can accurately read the gauge on that)
Feb 5, 2019
163
29
Wales
I used the Oxford digital pressure gauge until I got the topeak... just because I lost the Oxford one. I found the Oxford one, and the difference between them is 2 psi.
The best gauges in my opinion are the analog ones.
Matt Seabrook
62
47
St Austell Cornwall
I’m glad your gauge is accurate but tested against five other pressures gauges that read within 1 psi of each other it’s miles out. Thanks not including the track pump. I’m quite fussy about knowing the tools I use are reliable. All I can say is my Topeak gauge is a desk ornament. ?
Doomanic
🛠️Wrecker🛠️
8,702
10,342
Mine would be returned if was that inaccurate. The only time it had any issues was measuring shock pressure, but at 275psi I'm not surprised and it was most likely user error.
Doomanic
🛠️Wrecker🛠️
8,702
10,342
My bad, it was 225psi and the gauge is rated to 250.
552K
