Levo Gen 2 Turbo Levo Chain Rings - Gen 2 and Gen 3
67-LS1
8
California
I’ve got a 2019 Turbo Levo (Gen 2) and a 2024 Turbo Levo (Gen 3) and I would like to add larger chain rings to both.
The 2019 has a 32T ring and I’d like to go to 36. The 2024 has a 34T ring and I’d like to go to 38.
They are both 104 BCD rings but I can’t find anywhere that says if they are offset either way. +/- 1-2 mm would be hard to see with the naked eye while still installed so I though I would ask here.
I am also under the assumption that I can get the 2019 ring on/off with the spider and crank arm in place but the 2024 will require removal of the crank and spider. Am I correct here?
Thanks in advance for any insight anyone can offer.
67-LS1
8
California
If you haven’t removed the speed limiter, I see no reason to do this.
I’m not sure what you mean by “speed limiter”. If you are refering to the fact that the pedal assist runs out at 20 mph, I’m aware of that. I do have times where I would like to ride faster then the assist, ie, long downhills. Right now I can’t spin the pedals fast enough to go over about 26-27 mph. This could be over 30 with a chain ring change.
And since I have never, ever, ever used my 50t low gear, I’ll be fine climbing too.
577K
