My 2019 Levo came with 29 wheels and tires with tubes?
Just wondering what others are doing, take the tubes out and run tubeless o
Hi @SwissrobI was advised against this depending on skills level and pressure. Whilst running lower pressure the chance of a tyre burp and a big off increases, higher skills and pressures lower the chance of this happening. I will follow this to get feedback. I still run tubes and 500km with out a puncture.
Agreed, I have had zero issues since going tubeless and it has definitely saved me a number of puncture repairs trailside. As long as you run sensible pressures (higher if you are a more aggressive rider) then you will be fine.Hi @Swissrob
Not so sure that you were given good advice really?
IMHO you would be needing to run at silly low pressures to risk any real problems, I have unintentionally run as low as 6 psi on the rear and got away with it. As long as your tire width is proportional to your rim width and you keep the PSI in double figures you should be fine. I run 2.8 on a 35mm internal width rim and generally run 22 rear and 18 front but often run as low as 16 /12 if it's particularly snotty and never a problem with burping.
The benefits of running a tubeless setup really are worth the effort, removing the weight of the tubes alone will transform how your bike reacts, but perhaps the only downside is if you are not used to tubeless they can be a little tricky to setup. But there is plenty of help and advice on Youtube to see you through.
Hi @Swissrob
Not even a question......tubeless is the way to go!
However, there is no perfect system. On a recent ride, I did manage to put a 2-inch slice in the rear sidewall and had to walk out even though I was carrying a tube as a backup.
Good discussion. I’m thinking about going tubeless as everyone seems to recommend it. I haven’t really had a problem with flats - but then I’m probably not pushing things as hard as some and most of my riding is on forest trails with not too many rocky bits.
A couple of questions:
(i) Should I do both front and rear wheels? Someone told me I only need to do the rear.
(ii) Should I also use foam inserts, e.g Cushcores?
The latter are pretty expensive. Would they be worth it for an average rider?
Oh and I’m riding Maxis Minion DHR II 27.5 x 2.8’s
You lucky, lucky boy!I did thousands of kilometres with different bikes, only one puncture in my whole life, Schwalbe racing Ralph on fire road.. Period. No need to go tubeless, terrible mess.
Where does everyone ride to get so many punctures?
In the countryside, on bridleways and the like, and pretty much any of the forest trails anywhere in the UK will have the following.Where does everyone ride to get so many punctures?
Hawthorne trees/bushes have spikes that will go though your shoe! In addition, mature Brambles can be most unpleasant. Then there is Gorse, which while it can penetrate clothing, you'd have to be unlucky for any of their spikes to penetrate a tyre. When the farmers cut the hedges the trails can be inches deep in long wooden splinters, which may also contain spikes from the fore-mentioned threats. And I haven't even got on to flint, sharp edged rock, glass, nails........
The same just happened to me.Not even a question......tubeless is the way to go!
I’m pretty sure you will need some tubeless rim tape in addition to the valve and sealant.I have Schwalbe smart Sam tyres and tubeless ready rims on my Cube. Can I just install an appropriate valve stem and some sealant to go tubeless?
