Answered Trek powerfly 4 crank arm
Woodyboy
70
248
Uk
I’ve managed to bend a crank arm on my trek powerfly 4. I’m finding it really difficult to find a replacement, even Evans are struggling. Does anybody know what arms I need? It’s a Bosch gen4
Thanks in advance!
Doomanic
🛠️Wrecker🛠️
8,699
10,333
Any Trek dealer will be able to order you the correct part. Evans are a box shifter these days, have you got a proper LBS nearby?
Woodyboy
70
248
Uk
Any Trek dealer will be able to order you the correct part. Evans are a bos shifter these days, have you got a proper LBS nearby?
I had a small warranty issue as well so took to them as that’s where I bought it. They have been helpful but saying no stock anywhere. I was trying to search myself and no obvious which are the correct ones. I can contact trek direct ??
coregrind
95
80
BEAVERTON, OREGON USA
The stock set on the 2021 Powerfly 4 looks to be the FSA CK-220 in 165mm. If so, they're cheap. I bought a 160mm set and didn't have much trouble tracking them down in the US at the time. Nowadays, and in a different country, it might be a different story. The FSA part number for the 165mm set is 324-0055002090. Otherwise, you might invest in a pair that are higher quality.
Woodyboy
70
248
Uk
Thanks for your help, just went I needed
552K
