Travel fox dxp2 ( sag)
Poupy
35
10
France
Hello to you all,
I changed my rockshox on my decoy base for a fox dpx2, I do 90 kg and on the Rockshox I am 210 psi for 30% sag with 2 chips on the fox with I need 280 psi to be 35% sag
Is that a normal thing?
I know that the decoy is very progressive so I do not think it is necessary to add tokens
What are your pressures and configurations in your fox dxp2?
Thank you
rb.
388
262
San Jose, usa
I did the same swap and I put in a 0.86 volume spacer in my shock. But I like it as progressive as possible. Not sure about your pressure, seems a little high. But gotta do what is necessary to get the sag correct.
Maherto
56
11
Dublin
I am no expert but the shock has a max rating of 350psi. So what ever pressure you need to get to the recommended 30%. I have mine at 320psi and am running the second largest volume spacer cant remember the size though.
jk-
78
47
Around
When I had my dxp2 on my bike I had the psi around 280ish to get the sag i wanted. Like Maherto said dxp2 shocks have max pressure at 350psi.
Between different brands it will be different to get the right sag
Poupy
35
10
France
Okay, so it looks normal for a fox.
There is a big difference in pressure for the same person between rockshox and fox to have 30% sag.. 210 in RS / 300 in fox!
thanks
TransAmMan
154
142
Canada
Just remember there is very regimental routine to adding air to Fox shocks … cycling it 10 times every 25 psi to equalize positive and negative air chambers. Lots of info available online
If your doing this already … then I don't have a clue why it needs such high psi :cool:
Good luck getting it right and let us know the outcome (y)
Poupy
35
10
France
Yes I always do pressure with this method. I put 300 psi for 35 sag
The damper works like this
I think it is due to the fact that the decoy is very progressive and that the dxp2 and very sensitive in low speed
552K
