My new Kona Ebike has come with a Trans-X dropper post.
The post has an issue where you can press the lever, and nothing happens, you have to jump on the saddle and then it drops.
After that it works fine until you've not used it for a short while, then it sticks again.
How can l cure the stiction? l've unscrewed the clamp, greased the post and also tried silicone spray.
lt's still sticking. How tight should l screw the top cap down? lt's get hard to turn as you wind it down the threads, is it tightened fully or just to a certain point?
l set the air pressure to 250psi which makes it return great, once it's in the down position. But it's annoying pressing the remote lever, and nothing happens.
Once it's off the end stop it responds fine to the lever, it's just that initial move.
