PacificTourer
In 2017 I cut the bottom bracket out of my Yuba Mundo, TIG welded in a e-bike mount and fitted a de restricted E6000 motor. It’s now toured 5 countries, PNG, Solomon Is, Malaysia, Singapore and parts of Australia, done 30,000km, 4 wheel sets and now the engine is knackered. I would like to suggest it’s done more MTB than most MTB while it was in PNG.
I want to replace the motor with a current model, e8000, EPS, or an equivalent Bosch or Bafang with all cables and battery.
Seeking to find out the dimensions of the motor mounts somewhere, so I can work out if I should modify the mounts to fit, chop the existing mount out and replace with a current model from frame builders supply, or some other novel solution?
Any builders out there with spreadsheets on motor mount measurements?
